Question about Dishwashers
F28 code? F28 code flashing
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: WHIRLPOOL DUET SPORT WASHER FLASH FAULT CODE F28
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Posted on Sep 28, 2010
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
HE2T front load washer F28 flashes machine is locked clothes inside cannot open help
tre
ert
Sorry to read about your problem, I hope this helps you out.
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
error code F28
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Jan 03, 2011 | Kenmore HE2 Plus Front Load Washer
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jun 09, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
13 people viewed this question
Top Dishwashers Experts
Owen Barnes
