How to find a fault of crt tv HITACHI FUJIAN model: HFC-14251 its on standby mode, please help.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault is with its main board itself. Check the horizontal scan output section circuit. Check the horizontal scan output transistor for leak. Contact any service technician. As standby-light is there, the main power supply regulator section circuit to your TV is working fine. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 13, 2014
  • 556 Answers
SOURCE: Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Posted on Oct 08, 2007
  • 68 Answers
SOURCE: tv goes to standby
Yes require sodering iron lopt is the Line output transformer large cylindrical plastic item on circuit board that has a thick wire that connects to the CRT (tube) with cap on the end. Do Not Touch as 24
Posted on Oct 07, 2008
  • 277 Answers
SOURCE: hi have recently bought secondhand panasonic CRT
power supply faulty
Posted on Jan 19, 2010
  • 1121 Answers
SOURCE: have a Sony Trinitron TV that is in Standby Mode.
is a power supply problem. needs to be repaired. send to repair.
Posted on Feb 19, 2010
SOURCE: I'm trying to fix my 21 inch JVC TV, its on
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Posted on Aug 31, 2011
Do you have the serial number for the crt transformer for hitachi fujian hfc-34s60t pinp television???
Serial numbers are unique to each item they are assigned to, and there is no way to look them up, only part numbers can be referenced. We here are fixya don't sell parts or have any reference materials to look up part numbers, there are lots of online suppliers of TV parts for most every brand out there, just do a google search.
Nov 02, 2016 | Hitachi Televison & Video
My hitachi fujian HFC 21p66a does not have an av button. How do I get my dvd to show on the tv? And it only picks up one tv channel, how do I get it to pick up other channels?
sorry but not knowing your location, it is possible there is only 1 station . are you using an out door antenna .find inputs on your set and change it to air or antenna .
Oct 21, 2015 | Hitachi Televison & Video
Hitachi fujian tv
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 14, 2014 | Televison & Video
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Jul 07, 2010 | Hitachi Televison & Video
MY HITACHI HFC 21P66A SHOWS PICTURE ONLY BLACK AND WHITE. HOW DO I BRING BACK THE COLOURS?
Hi friend,,,
welcome to fixya
Commonly for Hitachi tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Hitachi C29-F800S 29" TV
Tvs stuck on standby
Please can anyone help me, my tv switched off itself cant switch it back on. it is on standby mode tried everything in vain the model is Toshiba 28/32YT56
Oct 09, 2009 | Philips Magnavox 20MS3442 20" TV
Goldstar TV (unknown model)
tv has a power supply fault requires service
Oct 22, 2008 | JVC AV-27530 27" TV
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
