Question about Whirlpool EL88TRRWS Refrigerator
Why my fridge working all the time
I even turn it down to minimum and it still work all the time
  • 2,509 Answers
Could be a number of reasons, the cooling coils at back clogged and not ventilating, a faulty thermostat, faulty control board, door not closing properly. Start by making sure the back is clean and ventilated, then look at the thermostat. Caution high voltages so unplug before checking.
Posted on May 12, 2014
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Freezer not freezing.just put new thermastat in it
fridges and freezers work on the following principal: the freezer area is cooled and the cold air is circulated and shared with the fridge area.
So the keys to a good working unit are first to set the freezer so that it is at the desired temperature, then adjust the fridge control to get the desired fridge temperature
air flow is the only thing that the fridge thermostat controls, so keep the clutter in the fridge to a minimum
also dirt and hair dust etc build up on most appliances that have a fan so clean the areas around the back and bottom of the unit
remember any time you work on an electrical appliance unplug it first
lastly fridges with frost free designs need to have a clear drain from under the freezer all the way down to the bottom where the compressor motor is make sure this is also kept clean
if this fails to solve your problem then likely there is a leak in the system or compressor problem, but if this is the case your freezer will not work correctly either
remember the only cooling is done at the freezer znd cold air is sent through the fridge
lastly obviously the fridge and freezer are highly insulated and sealed and these are both important
Sep 02, 2011 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
My propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Larder fridge running far too cold
I was told that it ispossible for a snall pin in the thermostat to stick and that vigorously turning the knob up ad down a few times might well unstick the pin
Tried it and it worked!
Jan 03, 2009 | Refrigerators
Hi I've got fridge/freezer Whirlpool ARC7470. The fridge stopped working despite the freezer being ok. If I want to make it work a have to turn the thermostat wheel to "off" (even the fridge...
hey hunnie,
well you have set the thermostat wheel to the minimum temperature due to that your fridge will work till some extent after that it will automatically off so set the thermostat wheel to the high level
Sep 03, 2008 | Refrigerators
Whirlpool EL88TRRWS Refrigerator Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
