Question about Tarte Increases Lash Volume By 424% Mascara Black (Tarte)
I want to become a model. I need to get some nice headshots to send out. I have crooked and chipped teeth though. How extensive is getting teeth fixed? bryanflake1984|
    Problem Solver:
  • 13 Answers
White filling can help to correct alignment and chipped teeth whilst keeping cost low. Teeth whitening with home trays might be an idea before doing the fillings
More impressive results can be achieved by braces and / or crowns. these are more expensive and the former requires time and the latter requires mild/moderate tooth reduction to allow for crown placement
Posted on Jun 15, 2014
After using anew chaini hit dirt. isharpenit withadifferntanglewillthat make a differencein cutting.
sure will , most saws have different angle cuts to teeth on blade this "angle" needs to be maintained as the "rake" teeth that are behind the cut teeth are set to provide a good way to wipe out cut debris (cut,rake,cut,etc.) this is how chain cuts thru wood , if one changes the cut angle on teeth the rake teeth might not do there job correct and saw bogs and "files" thru wood rather than chips thru wood ,takes longer ,more fuel, more effort , a look at saw cuttings tells the tale , more tiny file sawdust = dull chain --- large Chips and less dust = sharp chain
Aug 26, 2015 | Garden
What services do dentists offer?
The dentists working in Invisalign Braces London provides a wide range of services like:
a. Invisalign Braces
b. Treatment for crowding and spacing
c. Treatment for crooked teeth
d. Whitening treatment
e. Regular dental health check-ups
f. White fillings
g. Dental crown
h. Dental bridge
i. Dental implants, and much more.
Jun 24, 2015 | Health & Beauty
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Anything I load on to my kingston data traveler 32GB dt101 gets corupted & does not open. I attempted top reformat however problem persist.
the ram chips have become corrupted, either from pulling out the data traveler when it was working, in a folder, and or windows was still accesing it even though it has said it is safe to remove. If this is still under warranty then send it back to get it replaced. I have a couple of 32GB and 16GB thumb drives that have become corrupted just because windows didn't recognise them properly and just kept on accessing them continuously. Sometimes reformatting will fix problem as a short term fix. Just get it replaced ASAP.
Jun 19, 2011 | Office Equipment & Supplies
My chainsaw will not cut straight after chain was shrpened because I hit a rock.
If the chain is still not cutting straight, it is because it is not sharpen correctly...the cause of it cutting crooked is because on side of the teeth are sharper then the other side...getting it to cut straight again can be extremely difficult and time consuming...the teeth must be equally sharp and the depth gauge (or aniti kickback) part of the teeth also filed to the same dimension...
Often it is easier to just buy a new chain...
heatman101
May 08, 2011 | Husqvarna Garden
I need to replace all 4 wheels on model 4920#1 Delta crib. Are they available?
Contact Delta. If you are nice, sometimes they will send them for free.
Check for recalls on your crib because many are recalled. If so, maybe
they will send you a set of wheels free! Have your model number ready when you call.
The model number is on the mattress support board. Good luck!
Hours of Operation Monday through Friday
8 a.m. to 8 p.m. (Eastern Standard Time)
1-800-377-3777 extension 6221 or 212-645-9033
Fax: 212-645-9032
Feb 22, 2011 | Delta Luv Delta - Baby Products 5-in-1...
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
Ive just bought an xbox 360 live starter pack and the headset does not work?
the best thing to do is send the headset back or buy a new one for 10-15£
sniper87569 headshoting problems for the xbox
Jan 16, 2010 | Microsoft Xbox Console
Front diff. wont lock into 4x4. Transfer case is working. Vacume Dia. under battery tray is working. Could the shifting fork in the diff be broke
The cable from the differential to the accumulator should move somewhat freely. If it does not, then the cable may be froze up. You can lubricate it with some penetrating oil and work it to free it back up. You may have to remove it to free it up properly.You may find the cable shield towards the bottom end is broke off and the cable may completely be froze up, it's common on the Blazers. You can try pulling on the rod that the cable clips into in the front diff to disengage the front axle. If you cannot get it to engage that way, then you will likely have to pull off the passenger side extension housing to access the engagement collar and fork. If you cannot get it to engage by pulling on the fork in the axle, then you will likely have to disassemble it.
You will likely have to file down the leading edge of the gears. They should be beveled on the sides of the spline to aid in engagement. Hopefully yours is not chipped like the one in the front of my old S10. Mine chipped the splines on the axle and split the collar from being partially engaged under power
The right axle and has splines at the end of it. The Output Shaft slides into the carrier and has large teeth on the other end. The collar it has large teeth inside it that mate with the Output Shaft with the Fork.
The collar rests on the axle, the fork wraps around the collar. Then you push the 4x4 button or shift your transfer case into 4x4 it starts spinning the front drive shaft, which spins the carrier and the short shaft. Now your in 4x4, BUT the front axle needs to lock the right axle with the carrier. A switch on the transfer case routes engine vacuum to a diaphragm under the battery tray, that diaphragm pulls a cable which pulls the collar and forces it over the short shaft. Now your front diff is locked. When you take it out of 4x4 the vacuum switch closes and a spring pushes the fork and collar off the shaft unlocking the front diff.
The problem with mine I think is that the large teeth on the Output Shaft and the inside of the collar are worn at the tips, not allowing them to join together, and the more I drove it around with it clicking, thinking it would lock eventually it just wore the tip of the teeth more.
If that is the problem, You should not have to mess with the differential case. You should be able to get the passenger axle extension tube off, but it may require popping a ball joint, then disconnecting the CV shaft from the axle extension tube, which would allow you to then pull the extension tube.
Good luck and hope it's just the shift cable retaining clip in the housing that broke.
Dec 30, 2009 | 1997 Chevrolet Blazer
Canon powershot A560
you need to get camera serviced-usually lens jumps off track or is crooked and gets jamed-did camera get dropped?if older model than 1 yr usually 100-125 to repair-if new model still in warranty they will tell you someone broke it and it's not covered-as a last resort if you are going to toss camera anyway put pressure on lens as you try to zoom in and out or put lens between teeth and try to force back in place
Aug 12, 2008 | Canon PowerShot A560 Digital Camera
Tarte Increases Lash Volume By 424% Mascara Black (Tarte) Logo
89 people viewed this question
Top Tarte Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Tarte Health and Beauty Expert? Answer questions, earn points and help others
