Question about Pool & Spa
Intex portable spa it was fine then the temperature got to 100 n it cut off it show no codes just crazy things that look like lillte L n backwards c I have reset it the lights come on bht pressing the buttons still wont do nothing not even sure turn on
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
My spa temperature light is blinking. It is set at 104 and the temperature is showing 118. Why is the temp blinking?
If you can contact your spa manufacturer they will usually send you the manual for your unit at no cost.
If the temperature is set at 104 it is at the high end of the safe temperature for a human. 102 is recommended, and 103 is OK for 15 to 20 minutes maximum.
If your spa is actually at 118 degrees, it could easily cause very severe medical heat distress. I would strongly recommend NOT using it until you can get the temperature down.
It's possible that the blinking light is a warning.
Jun 14, 2015 | Intex Pool & Spa
My intex portable spa was working fine now it only has a long beeping noise and nothing on control pad will work. Help
Unfortunately, it sounds like your controller has failed? Try turning power off for 30 minutes, NOT 29 1/2
Then turn it back on.
This will reset all short term memory in the logics, of circuitry.
If still non operational, unfortunately Intex Sells NO repair parts, they build these in a such a way to replace complete components.
So...
Sqeak and squeak loudly!
Maybe you will get some help from Intex?
look here...
http://www.intexcorp.com/contacts
Jun 12, 2015 | Intex Pool & Spa
Code 90 on portable intex 200 gal spa
Sensing problem with sufficient water flow!
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
http://slink.intexdevelopment.com/b2cmnl/B2CMNLServlet?instantiate=B2cMnldownloadApp&action=pub_mnl&filnam=250IO_A0_1411_EN.pdf
Feb 28, 2015 | Intex Pool & Spa
My intex spa shows error 96 and 143 degrees F. water is cold
well first the manual should say what a error 96 is but i'll save you the trouble , the control is saying heater failure as the water should never be 143 degrees this would burn/kill you if you got in , id look at temperature probe 1st (its in pipe right past the heater ) and next id look at control itself , sometimes water intrusion dammage in controller makes for some "funny" and wrong things to happen
Oct 12, 2014 | Intex Pool & Spa
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
Aug 24, 2014 | TheraPureSpa New 2 - 4 Person TheraPure...
Intex portable spa error code 98 flashing
Bonjour
Je viens de monter mon SPA Intex et mis en route
Apr?s avoir r?chauff? l'eau jusqu'? 17 il a bugu? et met une erreur E98
J'ai appuy? sur reset mais rien n'y fait
As tu une id?e pour me sauver
Merci
Bises
Aug 16, 2013 | Pool & Spa
We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Aug 03, 2013 | Pool & Spa
Pool & Spa Logo
85 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
