Question about Garden
Right control lever stopped working.
The mower stalled on a hill.....I had to open the bypass valve to push down to level ground...then it would not start....I then pushed to the garage to jump start....closed the by-pass valves and started the engine.... left lever works just fine....no tractor movement with right control handle.
  • Bill Hays May 13, 2014
    Z425 zero turn........2006
  • 708 Answers
You need to list the model# series. and year of your unit.
Posted on May 13, 2014
My car stop when i release the gas and push the brakes in stop lights or intersections
POSTED 2 TIME, BUT THIS ONE LONGER. read other post answer now.?
your engines stalls! if engine stalls so does car.
BUT DOES IT RESTART EASY,??????
Does the restart, starter sound fast and normal or weak
can you prevent the stall with fast right foot action?
ever get a tuneup in last decade?
most stalls are caused by 50 things.
top of list is MISFIRING.
http://jeepdied.com/Misfire101.html
Feb 01, 2016 | 2006 Jeep Grand Cherokee
Can anyone tell me what is wrong with my mower?
it may very well be ready to blow up
you need a two cycle machine for hills, 4 cycle mowers are dumed
it slows on hills and stops because the crankshaft, camshaft, wrist pin and piston are not getting lubricated properly and just about to seize up
Mar 29, 2015 | Cars & Trucks
Tv lift does not raise to proper level the details below explain all this
Dear Ted
Sounds like the stop limit is incorrect. There are three possible ways motors establish a stop limit. The most common is a limit switch(a small black box with a lever or button that sops the motor when this lever/button is activated). There are two one to stop on the way up and one on the way down. If this is the case then the up switch is being pressed too early something might have come loose and is now activating this switch early. The second way is through electrical current monitoring. When the motor controller detects a higher current draw it stops. This happens when the mechanism reaches the travel limit and stops moving creating resistance to the motor turning and the motor daws a higher current to continue pushing. the motor controller senses this and stops the motor. Check to see that nothing is hampering the travel of the rails creating resistance. The third method is to program the motor controller for a specific time or motor turns to stop the mechanism travel at preset levels. This can be found in the installation manual.
Hope this helps.
Dec 13, 2014 | Televison & Video
Cub cadet i1042 zero turn doesnt seem to want to go forward when turning or even going strait sit moves very slow and when i go up a little hill it stops half way and then creeps up the hill it use to
If it's a hydrostatic transmission, I would have the transmission looked at. You may need to "purge" the system and check the fluid level.
The ones I've done called for the drive disconnects (the rod or lever which allows you to roll the tractor when the engine is shut down) to be in the flow bypass position. They also wanted the wheels off the floor, then the engine to be started, & the direction control to be worked SLOWLY to the front & rear positions 10-12 times. Then put the bypass valve back in its 'drive' position, fire the engine again & repeat the slow cycle of the direction control. The unit SHOULD be quieter now & perform better, but double check the oil level because expelling the air may have dropped it too low.
Jul 22, 2014 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Slow speed on one side.
Check to be sure there is not a lot of grass and debris packed in spaces that prevent proper movement of the control arms.
If the control arms have free range of motion then you will need to check your fluid level and purge the pumps.
To purge the pumps jack the unit up and place on jack stands so that the drive wheels are off the ground. Release the transmissions so that they are in freewheel. Start the unit, release the brake and work the control levers slowly to full forward then full reverse 6 times. Shut the motor off, lock the transmissions back into drive. Start the unit and work the control levers back and forth 6 times again. Take down off the jacks and check fluid level. If there were any air pockets in the pumps this procedure would have purged the air out.
Oct 01, 2012 | Toro Garden
My husqvarna zero turn mower has an auto safety shut off. I have isolated 3 (Brake, Left control level, and Right contol lever)trying to see which one was faulty, but I'm not sure where to go next. When I...
There should be a switch under the seat. The system is designed to stop all functions if no one is setting in the seat. I believe the seat switch has failed.
Check it out and let me know.
Regards,
Jul 20, 2009 | Husqvarna Zero Turn Mower Z5426
Craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
Jun 13, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Car dying when letting off gas
Sounds like it's your IAC (idel air control sensor).  The IAC is a computer-controlled air bypass valve located in the throttle body. It helps control idle speeds by allowing air to bypass the throttle plates as to increase the idle speed.  If the IAC isn't working properly the car will stall when you are not pressing the gas pedal.  It is located on your throttle body and is relatively cheap and a simple change since it is normally held in my two screws.  Let me know if you have any other questions.  Thanks for an honest ranking and for using FixYa!
May 20, 2009 | 1997 Buick LeSabre
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
