Question about Pro Power Exercise & Fitness
How do i take slack off the cable ? - Pro Power Exercise & Fitness
Hi, I do not have this unit however google search gives up : http://www.scribd.com/doc/93058121/PRO-POWER-Lay-Flat-Home-Gym-Inst-DI-v-08 assembly and use manual, hopefully the correct one. If so pay careful attention from pp23 onwards to the threading of the cable(s), and that they had not slipped off and be jammed beside the pulleys. Details of adjustment are given. Good luck. Les.
Posted on May 25, 2014
How do you tighten the parking brake cable
The parking brake cable are no longer adjustable. the e-brake pedal is self adjusting. But there is away to take up the slack. between the brake lever assembly and the body there is a small black lever the pointing straight down, this is also used to give your cable more slack when trying to disconnect or re-attache the cable. Again the is loctaed between the e-brake assembly and the body once you located it push it forward as far as you can and it should take out what ever slack you may have. If your planning to disconnect you well need another person. to get more slack you have to push that lever forward while anothe personis pulling on the cable from under the left front side of the vehicle and then use vise grip with just enoungh pressure to hold not to crush the cable. this well leave you enough slack to remove oo reattach the cable.
Jul 02, 2014 | 2005 Chevrolet Suburban
Que es error 5 tectrix personal climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
Screen shows error code 5
Feb 20, 2014 | RTO Tectrix Personal Stair Climber
Screen shows err 5
Honda accord kickdown cable adjustment procedure
if u want it to kick down later simply adjust more slack in the cable if u want it to kick down earlier make it tighter check the slack at the throttle body side adjust it to have about 1/4 inch slack drive and adjust acordingly
Oct 07, 2012 | 1994 Honda Accord
Clutch is slipping on my 2008 flhx how do [ adjust clutch beyond adjustment in cable
take all slack out of cable . take derby cover off loosin lock nut in center if pack tighten addj screw turn in till seats back out 1/2 to 1 turn tighten lock nut . take slack out of cable . hatleytalking.con ...good luck
Oct 29, 2011 | 2008 Harley Davidson FLHX Street Glide
Slack parking brake cable. is it adjustable?
Look under the left side of the vehicle along the frame rail. Follow the cable from the rear wheel toward the front. There should be a device attached to the cable. Tightening the bolt will remove slack from the cable
Jul 22, 2010 | 2006 GMC Sierra 3500
2005 FLHTCI Clutch Adjustment
follow the bable down from the lever approx 2 feet....right infront of the front cylinder...there is a rubber boot on the cable...pull back the boot to expose the adjuster....it will have a lock nut that you need to loosen...you will need 2 wrenches to do this...once the nut is loose you can make minor adjustments to the cable...remember to leave some slack in the cable....check the slack at the lever...iusually make it just a little under 1/8 of an inch.....if it wont adjust all the slack out, then you will need to adjust the clutch release mechanism under the round cover on the primary....i would suggest picking up a service manual
Apr 19, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
Exercise & Fitness Logo
111 people viewed this question
Top Pro Power Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Pro Power Exercise and Fitnes Expert? Answer questions, earn points and help others
