Question about John Deere Eztrak Special Edition Kit Z425 Z445 Z465
I have a John Deere Z425 after it stalled on a hill I opened the by-pass valves pushed to level..... I no longer have action right lever but left lever works fine.
I had to push some more to get to a jump start...... the lever handle moves the pivot at the hydraulic pump control.
  • 3 more comments
  • Bill Hays May 14, 2014
    I'm beginning to suspect there is air in the right system.....I remember opening the by-pass valve completely ....only to read the operator manual later to indicate one turn all that's needed..The long push with the by-pass wide open may well have sucked air into the system...How to bleed?
  • Bill Hays May 17, 2014
    All OK now. I devised a way to reverse flush the right hydraulic system.
    Add a Competently removed the by-pass valve stem and with the wheel jacked up I turned the right wheel as in reverse...fluid came out the vacated by-pass stem hole. I then turned the wheel as in forward till fluid came out the by-pass hole. I then re installed the by-pass valve stem. Removed from the jack and started the mower......WALLA!....everything worked as designed..
    I appreciate everyone who viewed my problem....This solution possibly could help others.
  • Charles E Paramore
    Charles E Paramore Jun 13, 2015
    Yes, Bill this was the cure for my z425 also. My mower had done the same thing. Thank you for you post
Have a John Deere 575 skid steer that the left wheels will creep backwards.
check for problem control valve for that wheel
valve not seating properly allowing pressure through to the drive motor
Jan 10, 2017 | John Deere Garden
Why does the battery go dead overnight after john deere z425
Need additional information...Check to see if it is the new battery or the electrical system first........ when the battery is "up", disconnect from the system. Remove both wires from the battery...connect the next day and see if the battery will crank the mower. I've experienced new battery's that have an internal short....Let us know whether battery or John Deere electrical system.....and we can troubleshoot from there...
Jun 16, 2014 | John Deere Eztrak Special Edition Kit Z425...
Right control lever stopped working.
You need to list the model# series. and year of your unit.
May 12, 2014 | Garden
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. Any suggestions
Bad/old fuel (must be less than 40 days old), water in fuel, clogged fuel filter(if equipped), oil level correct?
Apr 22, 2014 | John Deere Garden
John deere troubleshooting
check fluid level, if full first inspect the valve, if the valve is passing fluid check ram for leaks, most will leak a bit of they are older however a large leak can introduce air to the system and cause cavitation. be sure the right type of fluid is used, the wrong type will burn up your pump
Dec 11, 2013 | John Deere 240 and 245 Farm Loader...
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
How to replace coil pack on John Deere Z425
Concerning a Z425 John Deere mower. When I start the mower it shuts off immediately, when I try it again the motor cranks but will not start. any suggestions?
Sep 06, 2012 | John Deere Garden
John Deere Eztrak Special Edition Kit Z425 Z445 Z465 Logo
347 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
