Question about Pentair Garden
How to replace a Pentair dynamo strainer pot
I broke the side piece where strainer lid hooks to. How do I replace the strainer pot
  • 3 Answers
I really would need a picture to be more accurate. If you have no way to hold the lid on to get suction, you have to replace the front bowl (pot) as that is where the strainer basket is and how the flow is created. That bowl (pot) unscrews from the front housing. You have to be able to free the suction pipe from the bowl and have enough room to spin the bowl off. You may also have to remove the pressure side pipe if you do not have enough room to turn the bowl (pot) off. If you can not get the bowl off of the front plate, you will have to replace the bowl and front plate all at once.
Posted on May 18, 2014
How to replace a Pentair dynamo strainer pot?
I believe the pot is screwed into the pump body/volute. Lift the complete pump enough to turn the entire pot counter clockwise, to unthread it off of the volute.
May 12, 2014 | Pentair Garden
I have a 6 year old Pentair Dynamo 340210 pump for my above ground pool. The past 2 weeks, after I back washed the filter- the pump seem to not be pulling very much water into the filter and it is not...
It sounds like you have a air leak on the suction side. I am assuming the pump is operating at full speed. Check for a cracked line especially around fittings. Try cycling the back flush valve as well. I hope that helps.
Aug 19, 2013 | Pentair 340210 Dynamo Swimming Pool Pump...
Pump Leak
there is a cheap gasket/ o-ring that needs to be replaced
May 31, 2013 | Pentair Dynamo 1.5 Hp Pump & Motor Dynii...
New pentair dynamo pump 115v need to wire a cord to the motor
see side of motor for schematic low voltage move wiring or turn switch to 120 volt then black to L1 white to L2 green to ground or case
May 25, 2012 | Pentair One - Speed 1hp 115v Dynamo Pump...
The plastic where you screw the clear plastic lid on top broke on one side so the lid does't clamp down. Is there a way to repair this or replace just the tub part without buying a whole new pump? The...
PAC-FAB / Pentair Dynamo pool pump parts, Discount parts for PAC-FAB Dynamo pumps
This site shows a separate part for the strainer body, but I'm not sure it is separate.
Call them with your model number and they can tell you if it unscrews and sell you the repair part that you need.
Worse case, you might have to see if you can remove the entire pump casing and purchase that.
Gary
Feb 26, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
MY POT AND LID FOR THIS CROCK POT BROKE, HOW MUCH IS A REPLACEMENT
Believe or not, go to your local Goodwill Store! They have tons of crocks and the lids and the cookers separate frm each other that have been donated becase one of the pieces was broken and they donated the rest of the pieces. Lids and crocks typically range from $1.99 to $5.99 and you benefit your community at the same time.
Sep 17, 2010 | Rival 33511 5-Quart
Can I get a replacement for the ceramic pot which I just broke???
Aug 18, 2010 | Bravetti KC281HB 8-Quart Slow Cooker
Need a Replacement Lid for Rival's Oval Smart Pot Crockpot
I found something on amazon,click here and take a look: Amazon com rival replacement lid. I hope this was helpful. Cheers
Nov 17, 2008 | Rival 38601 Smart Pot 6-Quart
Garden Logo
52 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
Electro Med Services...
Are you a Pentair Garden Expert? Answer questions, earn points and help others
