Question about Exercise & Fitness
Why is my pro power cable too slack ? - Exercise & Fitness
How do you tighten the parking brake cable
The parking brake cable are no longer adjustable. the e-brake pedal is self adjusting. But there is away to take up the slack. between the brake lever assembly and the body there is a small black lever the pointing straight down, this is also used to give your cable more slack when trying to disconnect or re-attache the cable. Again the is loctaed between the e-brake assembly and the body once you located it push it forward as far as you can and it should take out what ever slack you may have. If your planning to disconnect you well need another person. to get more slack you have to push that lever forward while anothe personis pulling on the cable from under the left front side of the vehicle and then use vise grip with just enoungh pressure to hold not to crush the cable. this well leave you enough slack to remove oo reattach the cable.
Jul 02, 2014 | 2005 Chevrolet Suburban
How do i take slack off the cable ?
Hi, I do not have this unit however google search gives up : http://www.scribd.com/doc/93058121/PRO-POWER-Lay-Flat-Home-Gym-Inst-DI-v-08 assembly and use manual, hopefully the correct one. If so pay careful attention from pp23 onwards to the threading of the cable(s), and that they had not slipped off and be jammed beside the pulleys. Details of adjustment are given. Good luck. Les.
May 12, 2014 | Pro Power Exercise & Fitness
Err 5
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 22, 2014 | RTO Tectrix Personal Stair Climber
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
How do I remove the bar on my Poulan Pro PP5020AV
by undo'ing the nut on the side over top of bar , then the entire case cover should lift off that side and then the clutch is visible , slacking up on chain tension screw till the chain can round the clutch and then entire bar and chain should just fall away
Sep 07, 2012 | Poulan Pro PP5020AV 50 cc Gas Powered...
How to take up slack on mower throttle cable
My first question is why is there slack in the cable? If it's just the outer housing is drooping away from the handle where it runs down to the engine, you can use some plastic wire ties, or electrical tape, or for a short term fix, even twist ties (like for bread sacks).
The outer part of the cable should be clamped down near the throttle control. Loosening the clamp and moving the outer housing back towards the handle will take up looseness in the inner cable.
If it's a new cable, you may need to pull the interior cable out at the engine end and shorten it by cutting with pliers. Most cables have a solid wire in the center. The cable fits into a small hole on the throttle arm. There should be an "L" shape on the end of the wire--if you cut it off, make sure to leave enough room to make another the L-shape in the end of the wire--it's what keeps the cable from sliding around in the hole.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How do you adjust throttle cable on yardman push mower
If there is excess slack in the throttle cable, you can do 1 of 2 things. Either replace the cable, as over time it gets stretched out. Or you can look by the throttle and you should be able to slightly screw out the set screw and take a little slack out and then tighten the screw back up. If there is anything more I can do, let me know. Thanks.
Clutch is slipping on my 2008 flhx how do [ adjust clutch beyond adjustment in cable
take all slack out of cable . take derby cover off loosin lock nut in center if pack tighten addj screw turn in till seats back out 1/2 to 1 turn tighten lock nut . take slack out of cable . hatleytalking.con ...good luck
Oct 29, 2011 | 2008 Harley Davidson FLHX Street Glide
Cable to front drive system to loose
that cable your pulling on has adjusters you need to adjust it and tighten it
Apr 29, 2009 | Toro Lawn Mower With Toro Power Tools
Exercise & Fitness Logo
37 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
