I tried to pair my Saturn VUE with my cell phone but couldn't. When I spoke with the On Star rep he advised me that my vehicle was not equipped with Bluetooth. Is there a way around this? I would really love to pair my phone with my service....does anyone know how I can do it?
SOURCE: spark plugs on 2002 Saturn vue
just completed a plug removal and install on my '02 awd v6. if you have the time and patience it's straight forward; common sense was most helpful. to gain access to the plugs, both fore and aft, you must remove, in short, everything near to, associated with, the air intake system. common tools plus a 1/4 socket, with 8 inch extension to hold a #10 star bit. these star bolts are under the rectangular plastic plate atop the intake. once you have those out, disconnect all the wiring, carefully. lift the intake out, look for plug covers, fore and aft, ignition assembly lays atop each row of three plugs. with the hands of a surgeon, remove the ignition assembly, and by golly ye shall see your reward. easy from then on.
replaced my plugs with the iridium 'honeys'; marked improvement in starting, acceleration, smoothnes, noise, and gas mileage to the value of + 3.0%. changed out the oil with mobile1 extended performance, changed transmission fluid. took a shower. time involved, 7.0 hrs. dealer be damned,,priceless!
SOURCE: service engine soon light on 2003 Saturn Vue
Here is the definition of the code in GM manual:
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature, this indicates the engine is running cold, u need a thermostat
SOURCE: Service Engine light on Green line 2007 Saturn Vue
take the ground line of the battery and press the brake for a few minutes and if the life is still on have the vehicle scann and clear code and have the emission components for the vehicle check
SOURCE: how to add fluid to a 2004 Saturn Vue transfer case
well if it is a v6.. the stick is on your right(as you stand in front) and way down. It has a yellow handle, but hard to see.
if you have v4 probably doesn't have one they are sealed.
SOURCE: replace headlight bulb 2005 Saturn Vue
This operation is well descibed in the user manual that comes with your car.
