Question about Pc America Restaurant Pro Express
How do I add more inventory in restaurant pro express
Just need to increase the the inventory when I receive more product. If I got to the item screen the quantity is grey. So where and how do I add additional stock?
    Sergeant:
  • Pc America Expert
  • 310 Answers
In the OPTIONS screen, click ADMINISTRATIVE, then INVENTORY MAINTENANCE. After looking up the item you wish to change, click the INSTANT PO button in the lower right corner. Enter a description such as "INV ADJ" and hit ENTER. Enter amount of adjustment, not amount in stock. If you need to deduct, enter amount of deduction followed by the minus sign (-) then ENTER. Your IN STOCK amount should update immediately.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Posted on May 19, 2014
  • 32 Answers
SOURCE: An employee forgot to clock in for an entire shift
pretty easy, just clock them in as normal, then go to timeclock management in the manager menu and edit the times in that field (they don't look like they are editable, but they are).
make sure to check that the displayed date-range is appropriate!
Posted on Nov 30, 2009
Testimonial: "Many thanks, Master! Nice knowing that someone's got my back."
  • 310 Answers
SOURCE: i need someone familiar with restaurant pro
I can help you with all of that. contact me at sysadmin@ccybernet.com
Posted on Jul 13, 2010
  • 310 Answers
SOURCE: how do i do an inventory adjustment in restaurant
Go to the INVENTORY MAINTENANCE screen in MANAGER. After looking up the item you wish to change, click the INSTANT PO button in the lower right corner. Enter a description such as "INV ADJ" and hit ENTER. Enter amount of adjustment, not amount in stock. If you need to deduct, enter amount of deduction followed by the minus sign (-) then ENTER. Your IN STOCK amount should update immediately. If you are changing many items, memorize the description using CTL-C and paste it in using CTL-V.
B MATTERN
Posted on Sep 27, 2010
  • 310 Answers
SOURCE: Hi, I have restaurant pro express v 12.0. Is
You could program a key at bottom with the ON SCREEN KEYBOARD function using the TOUCH SCREEN SETUP. This will let you manually type in the item number or bar code number. One thing to note, if you do not use bar code numbers as your item numbers, you can still make this work. On your inventory screen, click on the green check box beside ALTERNATE SKU. Then type or scan the bar code and ENTER and SAVE. You now have both an item # and bar code # that will reference your items.
Posted on Nov 08, 2010
Testimonial: "thanks, for your help :)"
  • 310 Answers
SOURCE: I just purchased a restaurant that has Restaurant
On the main login screen, click FILE in upper left corner, click DATABASE MAINTENANCE, then CLEAR DATABASE. Pick the first option, CLEAR TRANSACTIONS. This will clear all the old invoices, but if there are any customers or employee records, they will need to be cleared by someone familiar with SQL. I'm available if needed.
B Mattern
Please return and give me a favorable rating if this helps or is of value to you.
Posted on Feb 23, 2011
Can you retrieve deleted items
Hi Alice,
yes you can if you know the item id. go into inventory and click add new item. choose type needed. put the item id in and any description and save. it should come back and say that number is in use and ask if you want to restore it. say yes. it should be back.
if you don't know the item id, it can be restore thru sql commands, but not for a novice.
Hi
Jun 26, 2014 | Pc America Restaurant Pro Express
Pcamerica
Hi Rick,
Does it send to kitchen at all? When you hit resend, are items listed set to go to kitchen in inventory setup? If they are, you may need to reload/repair RPE.
Jun 18, 2013 | Pc America Restaurant Pro Express
How could i set up mi shop/crogery store with pc america ? the items
You add items on the INVENTORY MAINTENANCE screen or if you have an existing list or database, you can import it into PCAmerica's database. You may need professional help with this, but if you have a large inventory, it would be well worth the cost.
B Mattern
Jul 08, 2011 | Pc America Restaurant Pro Express
How do I remove an item from happy hour on restaurant pro express
Go to OPTIONS, select SETUP, then TOUCH SCREEN CONFIGURATION. Assuming you have a different schedule for HAPPY HOUR, select that schedule on the right side of screen. Then click on ITEM & DEPARTMENT button. On the left, HIGHLIGHT the department your item is in. On the right, HIGHLIGHT the item you want to remove from your HAPPY HOUR menu. Near the bottom on the right side, uncheck box DISPLAY ITEM ON TOUCH SCREEN. Click SAVE AND EXIT. This should remove item from HAPPY HOUR menu, but not any other menu. Item will still be listed in inventory. You can re add it by just checking the box again.
B Mattern
Mar 09, 2011 | Pc America Restaurant Pro Express
How can i write a note to my kitchen?
Create a new inventory item in the NONE department with no price and set it to prompt for description and add the kitchen printer to it under printers. On your touch screen configuration, set one of the bottom buttons to a fixed item and make it the new item you just created. Now you can touch one button and send a note to kitchen with any order. You are limited to 30 characters/spaces but just hit button again for second line. After sending to kitchen, you can recall and delete lines if necessary.
B Mattern
Please return here and give me a favorable rating if this helps.
Dec 14, 2010 | Pc America Restaurant Pro Express
Nov 07, 2010 | Pc America Restaurant Pro Express
How do i do an inventory adjustment in restaurant pro express?
B MATTERN
Sep 27, 2010 | Pc America Restaurant Pro Express
How do I send notes to my kitchen printer
You first need to create a new inventory item.
1. Create a standard item in the INVENTORY Maintenance.
2. Call it NOTES and put it in the NONE department.
3. Uncheck all boxes under OPTIONAL INFO, the OPTIONS tab.
4. Click the ADDITIONAL INFO tab, uncheck all boxes but PROMPT DESCRIPTION.
5. Under PRINTERS, add the kitchen printer.
6. Save the inventory item.
7. Go to SETUP, TOUCH SCREEN CONFIGURATION.
8. Click on one of the 16 buttons in middle of page, an unused one. It should turn green.
9. On bottom half of page, set it to a FIXED ITEM.
10. Set caption to KITCHEN NOTES.
11. Check box to display button.
12. Picture can be left blank.
13. In ENTER ITEM NUMBER, type NOTES, the new item you created.
14. Click SAVE AND EXIT.
15. Log out of RPE. When you log back in, you should have a KITCHEN NOTES button. You have a limit of 30 characters. However you can hit button as often as you like to continue your message to kitchen. This should not print on customer's receipt.
B Mattern
Aug 29, 2010 | Pc America Restaurant Pro Express
How do i change prices in restaurant pro express?
under manager, choose administrative, then inventory maintenance. This puts you where you set item pricing. You then need to locate the item. 3 ways to do this. Use the NEXT or PREVIUOS buttons to scroll thru entire inventory. Or if you know the item number, type it in the search box and hit ENTER. Or click the LOOKUP button and search for item on this screen and then hit SELECT.
If this helps, please give me a good rating. If you need further assistance with RPE, email me at sysadmin@ccybernet.com or call 814-797-5722 and ask for *****.
Oct 26, 2009 | Pc America Restaurant Pro Express
'Choice or Pass Along Items'
you might mean modifiers, that's what i'd usually set up. there are choice items too though but i think modifiers are most useful for restaurants.
Modifiers: http://faq.pcamerica.com/file-lockers/pdf-locker/Creating_modifiers.pdf
Mar 02, 2009 | Pc America Restaurant Pro Express
Computers & Internet Logo
101 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Will Halftowaite
sunil dixit
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
