Question about Pentair Garden
How to replace a Pentair dynamo strainer pot?
  • Pentair Master
  • 1,631 Answers
I believe the pot is screwed into the pump body/volute. Lift the complete pump enough to turn the entire pot counter clockwise, to unthread it off of the volute.
Posted on May 27, 2014
My whisperflo wfk 3 has a leak from under the pump. How to repair it
you may have a crack in the pot housing, a leaking seal if the water is coming out under the motor( be very careful if so, shock hazard), or the drain plug at the bottom of the pot may be loose or broken. If you can isolate it to the strainer pot, then you may be able to replace just that. A leaking seal is tougher.
May 22, 2014 | Pentair WFK3 WhisperFlo Pump
I really would need a picture to be more accurate. If you have no way to hold the lid on to get suction, you have to replace the front bowl (pot) as that is where the strainer basket is and how the flow is created. That bowl (pot) unscrews from the front housing. You have to be able to free the suction pipe from the bowl and have enough room to spin the bowl off. You may also have to remove the pressure side pipe if you do not have enough room to turn the bowl (pot) off. If you can not get the bowl off of the front plate, you will have to replace the bowl and front plate all at once.
May 12, 2014 | Pentair Garden
Pump Leak
there is a cheap gasket/ o-ring that needs to be replaced
May 31, 2013 | Pentair Dynamo 1.5 Hp Pump & Motor Dynii...
The plastic where you screw the clear plastic lid on top broke on one side so the lid does't clamp down. Is there a way to repair this or replace just the tub part without buying a whole new pump? The...
PAC-FAB / Pentair Dynamo pool pump parts, Discount parts for PAC-FAB Dynamo pumps
This site shows a separate part for the strainer body, but I'm not sure it is separate.
Call them with your model number and they can tell you if it unscrews and sell you the repair part that you need.
Worse case, you might have to see if you can remove the entire pump casing and purchase that.
Gary
Feb 26, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
The pot on my Dynamo pool pump tightens in the horizontal position instead of the vertical position.Any ideas on how to get it to tighten in the correct position.
I'm assuming you mean whe you thread the strainer basket pot into the pump and tighten it it ends up being 90 degrees off center? That means you cannot turn it and additional 270 degree. Unthread and wrap multiplul wraps of teflon tape onto threads. Then I'd add lightly add some pipe dope. Tighten the assembly up, but stop when it is snug and aligned. The combination tape and dope should keep it from leaking, but remember this would be a suction leak, so check carefully
Jul 18, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Sand filter putting sand into the pool I've changed gasket,replace head,check latereals,checked the size of the sand we use..still doing it
With these pool filters, there are several things that you need to check if you have sand returning to the pools. First, check your laterals are not broken or cracked. Even the smalled crack can cause this to happen so really inspect them well. Also, your backwash rate could be too high. Try lowering your backwash flow rate and see if this helps. Make sure that your air strainer is not broken or damaged. Replace if it is.
Jun 22, 2010 | Pentair Sand Dollar 19" Filter with 1 Hp...
I am trying to fill the pot strainer with water so I can start the pool pump
If the pot is higher than the pool, it will never fill to the top. Just fill it to the inlet level and it should be enough.
Feb 05, 2010 | Pentair Challenger 3/4 Hp In Ground Pool...
Garden Logo
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pentair Garden Expert? Answer questions, earn points and help others
