Question about TaoTronics TT-BH01 Black Bluetooth Headset for Sony Playstation 3 PS3 Cellphone/Call Rejection/LED Indicator for Connection
Unable to charge
The dongle plugs in successfully, however I no longer get a red charging light.
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Hp 110 mini will turn on and work but wont charge and the light is blinking steady red. Does that mean the battery is dead or the charging circuit is fried?
If you perform a normal charging cycle on your Netbook and it does not work afterwards, the battery may be unable to charge and will need to be replaced.
Jul 27, 2014 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Battery light flashing red
If you are using AC, remove battery. Charge battery and remove when plugged in for a period of time. It will last longer, the battery has a finite number of charge cycles.
May 17, 2013 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
My sms audio by 50 cent wireless dongle stopped working after putting it for charging
When I plug in my dongle to charge the blue led light comes on but when I want to use it, it won't turn on??
Mar 08, 2013 | SMS Audio SYNC by 50 Wireless Headphones...
My dell d600 is not charging what is the solution and it always flash red light when it is plug to power
That means either the battery is no longer good anymore or the laptop is unable to charge and/or recognize the battery. Try cleaning the contacts of both the battery and the laptop when everything is unplugged and powered off with alcohol and a q-tip. But usually if a laptop is not charging the battery then most likely you will need a new one
Apr 13, 2011 | Dell Latitude D600 Notebook
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
TaoTronics TT-BH01 Black Bluetooth Headset for Sony Playstation 3 PS3 Cellphone/Call Rejection/LED Indicator for Connection Logo
21 people viewed this question
Top TaoTronics Radio Communications Experts
eradiostore
eradiostore
Are you a TaoTronics Radio Communication Expert? Answer questions, earn points and help others
