Question about Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661
I have a jet 10 in. left tilt exact-a-saw that will not tilt. The shaft is keyed to the hand wheel and even wi
The shaft is keyed to the hand wheel and even with extreme force applied to the hand wheel the shaft will not turn. I have used compressed air and a vacuum to remove excess sawdust from the trunion and rack and pinion assembly but to no avail. Are there other other possible causes to the shaft/ gear assembly being frozen? ( lock screw etc... )
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 69 Answers
First guess would be a lock bolt is tightened down. Second guess would be a 90 degree latch or stop. Take a look at this link from "mikestools": http://www.mikestools.com/download/Jet-Owners-manuals/Jet%20Tablesaws/708661.pdf.
Posted on Jun 26, 2014
FixYaSteve
  • 57 Answers
SOURCE: Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
Posted on Jun 14, 2010
  • 384 Answers
SOURCE: The blade will no longer raise or lower on my Jet
Make sure the set screws in the handle and gear are clamping against the shaft..
Posted on Jun 17, 2009
  • 384 Answers
SOURCE: jet 10
Adjust the stop screw under the saw top plate.
Posted on Sep 11, 2009
FixYaSteve
  • 57 Answers
SOURCE: I bought a used Jet Equipment and Tool Tilting
Jet's manual site is here. I didn't find that exact model number. It might be worth double checking.
If this post was useful, please vote. Thanks!
rowdy45176
  • 2176 Answers
SOURCE: I was ripping some 2x4s
How freely does the motor turn without the blade on it??? Also what does that blade look like, are the teeth worn or broken? As for the motor usually there are vent holes in it and I would just try and use compressed air to clean as best asa possible. If the motor does not spin freely it could be dirt or possibly bearings. Let me know
Posted on Aug 12, 2011
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
TABLE SAW MODEL JTAS-10-1 SERIAL # 9031109
my table saw jet model jtas-10-1 serial # 9031109 stock # 708510
Aug 21, 2010 | Jet 10" Xacta Saw Left Tilting Arbor...
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
How do you cut angles on this saw. It was given to me and I can figure out everything else but cutting angles. Thanks
When you are facing the front of the table saw. Right above the Dewalt logo, there is a hand wheel that if you crank clockwise - it will tilt your table saw blade to the angle shown where the hand wheel is.
May 12, 2010 | Dewalt DW746X 10" woodworker's table saw...
I bought a used Jet Equipment and Tool Tilting Arbor Table Saw - CTAS-10-LFR. It stated once but now will not start. How do I locate a user manual?
Apr 06, 2010 | Jet Saws
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0908018-00004.png part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
Mar 19, 2010 | Craftsman 10" Table Saw
How to adjust my til tof my 10
When you are facing the saw as if you would be operating, there are two adjustment wheel on the front and right hand sides of the saw cabinet. The front wheel adjusts the blade height, the wheel on the right side of the cabinet adjusts tilt. Each of these wheels are equipped with a locking nut, a smaller wheel in the center. this must be loosened before any adjustments can be made and should be tightened before operation. If there is significant resistance while trying to adjust either of these it may be a result of misaligned gear or excessive buildup of dust and shavings on the gearing.
Feb 14, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661 Logo
75 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
