Question about HP DesignJet 4000 InkJet Printer
How can i make my HP Laserjet 4000 print darker
Sandy4u
  • 107 Answers
SOURCE: darker color printing
dear Friend pls check your print Quality in printer preference setting ,is it possible due to Hi density (print Resoluction)
other wise Check printer on other New computer with new Printer Drivers Installation
Posted on May 30, 2008
POCBM
  • 121 Answers
SOURCE: HP 5550 Laserjet prints dark
The only time I saw a color laser Printing darker than normal the issue was tranfer belt. The condition you describe matches the problem I was involved in and the tranfer kit fixed the problem.
Hope this helps
Posted on Mar 15, 2009
POCBM
  • 121 Answers
SOURCE: Where do I change the IP/Gateway/Subnet on HP LaserJet 4000
You can set these on the printer using the EIO menu.
Press menu until EIO menu appears.
press item
Config network NO should show. press value YES should show.
press select.
Press item until config tcp/ip NO shows, press value Yes press select.
This should get you into the tcp/ip menu.
use item, value and select keys to navigate to the setting you want to change.
hope this helps
Posted on Mar 24, 2009
  • 25 Answers
SOURCE: LaserJet 4000 driver problem
I had the same issue. I completely uninstalled the pcl 6 drivers twice and reinstalled and the printer mysteriously worked just fine.
Posted on Aug 10, 2009
  • 990 Answers
SOURCE: HP LaserJet 4000 prints horizontal drops down the
Hello sir; It's about time to replace drum cartridge.
Posted on Oct 02, 2009
Testimonial: "Thanks for the advise."
HP LaserJet 4000 Duplexer
I realize when I say this that you will be a little skeptical but I will say it anyway . the Paper may be damp - do you notice any curling from your print if only printed on one side? this is the easiest way to test for damp paper- while the paper is damp the Electrical resistance is much higher than when its dry and this is what typically gives a Light copy however once the paper has been though the Very Hot fuser rollers to \'fix\' the first side, the paper has been force ably dried and so the second side is much Stronger in toner. try a new ream of paper and see if that helps
Jan 22, 2014 | HP LaserJet 4000 Printer
My laserjet 1100 printer prints to light. How do i get it to print darker?
Go to driver setting and then goto printing default then advance then change Ret as default
Jul 26, 2010 | HP LaserJet 1100 Printer
Oct 02, 2009 | HP LaserJet 4000 Printer
Aug 10, 2009 | HP LaserJet 4000 Printer
How do I make the printing darker
go propertis -> device settings ----> change the print dencyty
Dec 30, 2008 | HP LaserJet 3050 All-In-One Printer
Printing problem
The printer itself is printing, but when I stalled Laserjet 4000 and try to print it shows ERROR even printing test page. I do not know why my HP laptop Vista cann't recognize the printer!
Thanks,
Iyaad09
Nov 23, 2008 | HP LaserJet 4000n Printer
Hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Darker color printing
May 29, 2008 | HP LaserJet 2420dn Printer
Pale print on PDF files
It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
Jul 25, 2007 | HP LaserJet 4345mfp Printer
HP DesignJet 4000 InkJet Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
