Question about Garden
Repair manual poulan pro model PB195h42lt
Service repair manual, deck engauges when lowered, but will not dis-engauge when raised
  • 7,733 Answers
Posted on May 12, 2014
  • 5 Answers
SOURCE: I have poulan pro model #PR55RG21CA Can not find
193664X479 is the new part# for a lower handle. (Tip: PR55RG21CA is invalid, perhaps you have a PR55R621CA). Good Luck.
Posted on Jun 27, 2009
  • 16 Answers
SOURCE: i have a cub cadet model 1450 hydrostatic it will
2 valves on top of trans under finders
Posted on Oct 17, 2009
vincob
  • 718 Answers
SOURCE: Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Posted on Oct 22, 2009
al_kupchella
  • 843 Answers
SOURCE: poulan pro, right out ofr the box model
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Posted on Jul 28, 2010
roadtech7
  • 297 Answers
SOURCE: cannot have blades engauged when in reverse mower
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
Posted on Dec 11, 2010
I have a Poulan Pro 30 414 snow blower.When I engage my self propel handle the wheels do not engage
might handle cable not be pulling far enough on drive engauge arm ? cables do stretch ya know
Feb 03, 2015 | Poulan Garden
Craftsman Self Propelled lawnmower will not allow me to pull starter cord out. Why? Very new mower 917.370433. Has oil and gas in it.
is your self porpelled engauged is your blade break dis engauged take the plug out can you turn blade by hand did you hit something check to see if blade is bent let me no what happens
Aug 31, 2014 | Garden
Cutter deck won't stay on
well since you don't mention a model number i'll ask ,a switch to engauge or a lever to engauge deck ? if a switch it could be a safety switch (somethings not set correct to be safe to engauge deck) or a lever to engauge ck the drive belt i'll bet it's worn loose or broke
Nov 24, 2013 | Mtd Garden
Clutch
I suspect that you have the clutch plate in back to front and the hub centre spring cases are hitting the fly wheel bolt heads. The raised section of the hub centre should be facing the gear box
Jun 04, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Need to put drive belt on poulan pro model pb195h42lt
You can search on amazon for belts... take a look: Amazon com Craftsman 42 in belt. I hope this was helpful. Cheers
Sep 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
HAVE LTX1000 GOLD IN COLAR blades will not engauge cable to engauge is broke .WHERE CAN I GET CABLE MODEL NUMBER IS WORE OFF?
You can try this model # 917.272440 and go the Sears Parts Direct http://www.searspartsdirect.com
If you are from the US you can get it directly from sears. Here is the part # for the cable 175067
Jun 25, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Motor stalls when blades are engauged
You should check the blades for free rotation. with the machine off and in neutral, or disengaged, try and move the blades. You should be able to move them some. Get a mirror and use it to look under the deck to see if there is anything caught in the blades or in the way of the belt. An obstruction here in the deck would stall the engine.
May 03, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
WANT TO RAISE THE BLADES TO CUT HIGHER GRASS
There should be a lever with notches on each wheel to raise the mowing deck higher or lower. Make sure each wheel is the same height.
Jul 12, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
