Question about Samsung SyncMaster Computers & Internet
Monitor keeps blinking every few minuts
Blinking
  • Samsung Master
  • 7,733 Answers
Potential Problems:
Cables
One possibility is that your cables are messed up. The 15 pin connection cable could be malfunctioning. You should get a new cable and replace it to see if it helps your situation. If not, the problem lies somewhere else.
Environment
There could also be an electromagnetic interference affecting your computer. You should move the laptop around the building or room to see if the position of the monitor changes the flickering. If it stops when you change positions, then there is something in the virtual environment affecting your monitors ability to display properly.
Display settings
If your display settings are improperly set, then your screen could flicker as a result. You should go into your desktop main screen, click Properties > Settings > Advanced > Monitor, and set your screens refresh rate at around 85 hertz or less.
Video card
The other possibilities are that the video/graphics card that was integrated into your computer has stopped working. You should switch it out with a new one to see if this helps your situation.
Monitor
Try to plug your monitor into a different PC/laptop. If it works properly, then you have an internal computer problem. You should also update your monitor's drivers just in case.
Posted on May 12, 2014
After a few minutes my monitor starts blinking
this is power issue please check in alternate power socket else check power cable
Feb 11, 2014 | Samsung 923NW 19" LCD Monitor
Samsung SyncMaster 731B Monitor blinks on and off.
It sounds like you have bad capacitors on the power supply board. The capacitors in the power supply filter the power, when they fail the power supply can not maintain operation. The blinking is caused by the power supply starting up, shutting down and restarting again. The monitor is repairable, you will need to replace the capacitors on the power supply board. 8 capacitors will need to be swapped out. Here is a link to a repair kit with the correct parts.
http://www.ccl-la.com/catalog/product_info.php?products_id=215
Apr 19, 2013 | Samsung SyncMaster 245BW Monitor
The power LED of my compaq monitor blinks when powered. Sometimes it works well but after 20 minutes display disappears and it blinks the power LED.
if the light blinks orange after a few minutes after use. The monitor would either require repair or replacement since the power board has gone bad.
Thanks
Proton
Nov 13, 2010 | Compaq Presario 5000 PC Desktop
Good Morning, My monitor keeps blinking and on the display you can see it keeps switching from analog to digital, i am using a dvi cable, and it is set to digital via the monitor, the weird thing is it...
My samsung monitor model 2233SW PLUS keeps flashing on and off and if i press the side button a menu type magic bright comes and shows whether to change in cinema ,custom ,text,internet mode etc,and when this option comes it doesn't flash and after 10sec this option goes off then again it keeps flashing in 5 sec. and the menu option doesn't come if by chance it comes than again for 2 to 3 min it stops flashing sometimes for 5 min .please help good-morning-monitor-keeps-blinking-orr1pjn3khwbyjvnsjgmppfg-5-0.jpg
Sep 03, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
Nokia 800+ monitor - screen is blinking approx.
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 17, 2010 | Nokia 800 PRO+ Monitor
HP vs19 monitor does not turn on.
You may have to inspect the inside of the monitor. You may have to dry it out from the inside and look for burned component which may be caused by a short due to the moisture.
Aug 15, 2009 | HP vs19 (Silver) 19" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Jun 12, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Blinking picture until warmup
On Sony TV's they monitor the current drain on all three electron guns Red Green and Blue. Until all are somewhat equal it will keep the CRT blank. As the set ages it means that it might flash a few times until the cathodes are good and warmed up.
Jan 28, 2007 | Sony KV-32V36 32" TV
Computers & Internet Logo
49 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
