Lanier LD335c "no black toner" error
Replaced black toner, replaced drum, cleaned unit. Still getting the same error. Machine will cycle through like it is loading the toner but then comes up with the same error.
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
SOURCE: Black toner spots appear on print outs
You have something stuck on your drum. See page 125 of your manual to clean it--it's just isopropyl alcohol on a Q-tip, but don't scrub. This happens (too) often to some people I know.
Posted on May 04, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Apr 25, 2014 | Lanier Ld328c Ld335c Type R1 Toner Black...
Grinding noise LD016
Lubricated the bushings on the black foam roller on the inside of the right hand door. Toner leakage is unrelated unless the drum unit gears are causing the noise, in which case, it must be replaced.
Apr 16, 2014 | Lanier Office Equipment & Supplies
Not want to read the new toner
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
Feb 08, 2014 | Lanier Ld328c Ld335c Ld345c Black...
Hello, i just replaced the black toner of my IR 3200 and i get the error code E000020-04a0. Can anyone help me please
E020-04a0 is a defective drum unit or a drum unit unable to produce the correct color density needed by the machine. E020-0Xa0. X being the color the code points to, count from left to right if you open ur toner door and look at the colored stickers. Just Replace the black drum and ur good to go Part Number is 7625A001AA
Mar 02, 2012 | Canon imageRUNNER C3200 Copier
Prints are having black lines and smudges along the sides of the paper. What do i need to clean?
Unfortunately when it comes to toners and drums there isn't much that can be fixed with cleaning. It sounds like either your toner cartridge is worn or defective and spilling toner, or your drum could need replacing and therefore is acting up. To check if it's the drum, pull out the drum unit and look at the drum roller (but don't touch it!) you should see streaks or color changes on the roller in places matching where the smudges on the paper are if the drum needs to be replaced.
My bet is on the drum. Drum units are fairly easy to get a hold of, since it is a "replaceable" part of the printer. And if you can install the toner you should do fine with the drum unit as well.
Hope this helps, good luck!
Aug 18, 2010 | Canon imageRUNNER 1023iF Black and White...
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
Jun 16, 2010 | Lanier UNKNOWN
How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
May 25, 2009 | Lanier Office Equipment & Supplies
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
18 people viewed this question
jasbo
jasbo
