Question about Hoover H3044 FloorMate SpinScrub Wide-Path Hard-Floor Cleaner Upright Wet Washer
Hoover h3045 will not dispense water - Hoover H3044 FloorMate SpinScrub Wide-Path Hard-Floor Cleaner Upright Wet Washer
2 Suggested Answers
  • 13 Answers
SOURCE: my hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
Posted on May 25, 2010
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
My hoover floormate will not dispense water
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate hard floor cleaner is not sucking as stong as it use to. What can I do?
Sounds like the squeegee may be old and need to be replaced. Check that first. If you need a new one you can follow this link.
part number 93001095
http://www.usavacuum.com/h3040-h3044-h3045-s/213.htm
Feb 21, 2010 | Hoover H3044 FloorMate SpinScrub Wide-Path...
My hoover all terrain does not seem to dispense clean water very well, is there a solution?
This machine does not use a pump of any kind to dispense water. It is just gravity flow. That is the best that it can do bases on its' design.
Dec 01, 2009 | Hoover Vacuums
Will not pick up water
Hi, Make sure you have the selector switch set to position "C" Wet Pickup. release the trigger. make sure the recovery tank is empty and clean as well as the filter in the top of the tank as there is an automatic shut off valve in this tank. All of these parts are washable and if you have been using it dry it still needs to be cleaned. You also need to make sure it is all back together correctly so it seals. Good Luck!
Feb 02, 2009 | Hoover H3045 Vacuum
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=565323
Hoover SteamVac deluxe
Posted by stripes9 on May 02, 2008
The solution will not dispense from the machine but will still dispense from the hose.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have 2 problems, #1. The trigger assm may be loose or broken and is not releasing the solution from the water solution tank or #2. The valve under the water solution tank could be shot or broken. If so, then the water solution tank is one assm and you would need to purchase a new or a good used one to replace. Please, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3044 FloorMate SpinScrub Wide-Path Hard-Floor Cleaner Upright Wet Washer Logo
18 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
