Question about Cell Phones
Screaches when talking to someone
I am told that when I'm on the phone, it makes a horrible sound. It is described as fingers down a chalk board.
  • 63 Answers
This can be down to poor signal.
You could try a replacement SIM card.
As this sometimes resolves the issue.
How strong is your coverage signal ?
Posted on May 13, 2014
I have 93 Lexus Ls400 when I hit the gas it makes a screaching sound as thou it needs a belt.Someone told me that it could be the buschings in the alternator. What could be my problem?
first look at belt if loose worn cracked glazed or just plain old and worn out change because a bad belt makes noise when slipping on pulleys ------if belt is good than look at belt tensioner ---- and pulleys to all components ---and listen to the area when vehicle running for grinding or squeal
Jul 24, 2015 | Lexus Cars & Trucks
The black board of my heart
THE BLACKBOARD Of MY HEART by HANK THOMPSON
When I was young and I went to school they taught me how to write
To take the chalk and make a mark and hope it turns out right
Well that's the way it is with love and what you did to me
I wrote it so you'd know that I was yours eternally
But my tears have washed I love you from the blackboard of my heart
It's too late to clean the slate and make another start
I'm satisfied the way things are although we're far apart
My tears have washed I love you from the blackboard of my heart
[ fiddle ]
If you'd been true the way you should and not have gone astray
Those tears would not have fallen down and washed the words away
No need to talk for if the chalk should write those words again
It will be for someone else not things that might have been
But my tears have washed...
Jun 13, 2014 | Games
My tv making a screaching sound when we turn it on and no sound and then screaching
try to play dvd if the sound is fine you have loose connection on your cable box reset all connectors.
if the problem still there you have faulty sound board or main board if it is built in..
Nov 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
We took off the front of the dryer.. the belt needs replaced.. however there are two small wheels in the back that make the dryer spin.. and one is good, the other is very very loose and is making all the...
i believe you are talking about the drum roller here is a website with the part:
http://www.repairclinic.com/Dryer-Axle-Roller-Shaft-Wheel-Parts
there is a c-clip that you have to remove and it slips right out. Good Luck Tim
Apr 02, 2011 | Dryers
I have a Maytag Heavy Duty Quiet Series 200 Dryer, and when I turn the dryer on is makes a horrible screeching sound. Like metal grinding against metal. What do I do?
That's easy, first of all you must have the Dryer on flat floor I mean verticly right. And try not to put too many clothes to get dried.
Sep 12, 2010 | Maytag Dryers
When it is on the rinse cycle it makes a horrible sound
could be a clutch or drive tube problem, on the bottom of your basket drive tube is a thrust washer,it eventually wears off the boyyom of the tube and your clip that holds on your brake release arm falls off breaking your clutch arm and thus no spin will happen ,, sounds like yours is grinding off the bottom of the basket drive tube,, mine was always screaching on the rinse spin and finally gave out when it wore the bottom off my tube, went and bought a used tube installed it with a new clutch and works fine now no more screaching!
Feb 16, 2010 | Kenmore 24032\24036 Top Load Washer
Piece of chalk sucked into vacuum
Yes, it is stuck somewhere in the vacuum. Turn it upside down, and you will probably find it lodged. Also could be lodged in hose somewhere.
Jimh
Jun 01, 2009 | Dirt Devil Vacuums
Lubrication?
It does sound as though it could be a lube issue. Use a light white grease to lube the bar the head runs on. Do not use things like WD40 or 3-in-1 as they can be damaging. Also check that any FCC cable to the moving parts are not just catching on an inner surface somewhere. This can sound like finger nails down a chalk board.
Jun 14, 2007 | HP 920 Plain Paper Fax
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
