Question about Husqvarna 223L
How do I put together throttle control for ahusqvarner 223L trimmer throttle repair instuctions
How do you put back together throttle control on a husqvarner 223L trimmer
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: how do load a dual line trimmer
Cut two separate pieces of string, about 7 ft. each. Stick the end of the lie in the hole on the inside of spool. Wind clockwise onto spool, putting the line that is closest to the ground on first. Once you have winded this piece on, lock the last 4 inches of line through the slits on spool. Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer. Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 11, 2009
  • 149 Answers
SOURCE: husky 223l trimmer will run but not wide open!
If its fitted chack the spark arester in the muffler, check the fuel quality or the carby diaphram is hard
Posted on Jul 02, 2010
  • 2239 Answers
SOURCE: HUSQUEVARNA LAWN TRIMMER 223L.
Its a full strip down to replace the cylinder, this is due to the crank shaft being sandwiched between the cylinder and the crankcase base,once the engine is parted from the tube houseing its juat a matter of diss connecting the throttle wire, the fuel hoses and removing the fuel tank, then undoing all the bolts holding it together, just take photos as you go, and put all the bolts and screws into the parts you take off, the cylinder will be sealed to the crankcase with instant gasket, and will need to be re sealed, the part no. for the cylinder and piston is 537032008 check the web for a price, the retail price in the UK is £176.72 plus tax, pretty expensive!
Posted on Jun 30, 2011
SOURCE: husqvarna 223l trimmer
put a meter to the spark plug wire and see if it fires. Make sure all lines are clean.
Posted on Jul 23, 2012
I need instuctions on how to put back the throttle assemble for a husqvarner 223L trimmer
Hello Ronny
I'm not fully familiar with that model however I have found a diagram that may help you. The image is a little small but it may give you an idea of the springs location.
May 12, 2014 | Husqvarna 223L
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Why won't my Husqvrana 223L trimmer crank?
Electrolux products are junk, should have bought a stihl.
May 08, 2013 | Husqvarna 223L
To much gas after replacing primer bulb
The lines can only go on 2 different ways, if the primer bulb is filling them im guessing its the corrrect way. However your friend may have tried adjusting the carb before he gave it to you. I'd be looking at carb settings or a sticking needle.
Sep 20, 2012 | Husqvarna 223L
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
Husqvarna 223l trimmer
Jul 23, 2012 | Husqvarna 28cc Gas Line Trimmer
HUSQUEVARNA LAWN TRIMMER 223L. PISTON SCORED. NEED TO REPLACE. HOW TO AND WHERE GET GOOD PRICE ON REPLACEMENT PART.
Jun 30, 2011 | Husqvarna Garden
Husqvarna 223L Logo
74 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
