Question about Garden
Castel garden manual - Garden
2 Suggested Answers
  • 252 Answers
SOURCE: I need a diagram for
pauly46_0.gifpauly46_1.gif hi there winger1886
pauly46 here
with 20/122 the blade timming must with one blade vertical and one blade horizontal
doesnt matter which one but as long as there is 90 degrees between blade as the rotate
in the picture the r/h blade rotates anticlockwise and the l/h blade rotates clockwise
the picture for belt / blade timming is straight forward - loosen tensioner rod and back it off completely , loosen 2 x bolts under the two toothed pulleys and remove the 2 belt guide/ stoppers from the l/h side - place both blades in the rqd position ( you may need someone to hold other blade in rqd position - fit the belt onto pulleys as in the diagram- continually check while fitting that timming has not moved from where you placed them ( they have to be 90 degrees from each other ) and then tighten the tensioner rod to hold position - rotate by hand recheck timming - if good loosly fit guide the 2 guide stoppers to l/h side and place 3.5 kg of tension at the middle point of the longest run of timmed belt ( belt should only deflect 10 mm with 3.5 kg of tension )
once tensioned tighten the 2 bolts under the toothed pulleys and tighten loc nut on adjuster
tighten the 2 stopper / guide nuts
in the picture the left hand blade is a l/h thread undo it right and tighten it left
the blade on the right is a normal thread left loose - righty -tighty
cheers hope it helps
Posted on May 23, 2011
I have a castel garden xe80 rideon wont start the box the pcb held in melted the pcb board warm no fuses blown no sign of shorted wires
If the pcb got hot enough to melt it's case then the pcb is bad. You cannot visually inspect most electronic components for damage.
Jul 17, 2016 | Cars & Trucks
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Can faber-castell permanent markers be used to make designs on cloth that must be washed in the washing machine?
The best way to know for sure is to try it - it may be dependent upon your choice of detergent and the chemistry of your water.
Nov 11, 2013 | Faber Castell/Sanford Ink Company Super...
Shaft removal from 200 yahama
There will be a big castellated ring nut, punch back the locking tab/sIf you don't have the special tool, you can use a punch, Just be careful you don't hit the casing, and replace the castellated nut with a new one?The prop shaft bearing carrier will the pull out, not quite that easy but it will pull out! This will give you direct access to the drive shaft nut so you can remove the drive shaft. You need a work shop manual!
Feb 16, 2012 | Boating
Where can I find a manual in English for a Faber Casteel slide rule?
Welcome to Fixya.
Please follow the link below for the slide rule manual :
Slide Rule Manual
Thanks for using Fixya.
Aug 19, 2011 | Faber Castell Toys
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
Our Transtherm Castel wine cooler is constantly accumulating ice along the top and bottom in the inside back of the unit. Is there any way to prevent this.
There is an air leak, cold is sucking in air from a faulty seal either at the back of the unit check any obvious joints or door seals are faulty?
May 12, 2011 | Transtherm Castel
Operating instructions for a Transtherm Castel
Go to the transtherm web site(type "transtherm" into google etc) click on the "Technology" tab at the  bottom of the page and download the pdf file at the  top of the resulting page.
Mar 02, 2009 | Transtherm Castel
Lawn Mower Repair
if the mower is a castel garden the blade boss above the blade may be sheared and needs replacing otherwise top cover over deck has to be taken off to adjust timming belt
Oct 19, 2008 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
