I stripped the head of the shaft end bolt of my Frigidaire front load washer. How can i get the bolt out ?
  • 148 Answers
There is a special socket set made for stripped nuts and bolts. Sears sells it. There are about five sockets in the kit, each covers a couple different sized stripped nuts/bolts. The socket is spiraled inside and tightens onto the stripped head as you turn it counterclockwise to remove..... DW
Posted on May 13, 2014
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
SOURCE: cant remove shock absorber "bolt/pin" frigidaire frontload washer
one end of thosepins has a tab on it, mash the tab with pliers while pullingon theother haundi24
Posted on Oct 13, 2009
Testimonial: "You knew exactly what i was talking about even though my question was a bit vague and confusing. I appreciate it a lot"
  • 50 Answers
SOURCE: front load frigidaire washer w/ error code
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Posted on Jan 06, 2010
Unit starts, fills, you can hear a whirring noise when motor tries to rotate drum
IF you are lucky, the spline of the motor rotor has stripped out. It is an easy repair (about a 2 on a 1-10 difficulty scale), and the part carries a 5 year warranty (minimum, up to 10 years on newer models) Remove back cover, unscrew bolt at center of motor, pull rotor off. If spline is stripped from rotor, replace rotor and you're done. IF SPLINE IS NOT STRIPPED ....... Oh s***! The drive shaft has broken loose from the three arms which attach it to the drum. (the part is called the "spider") To repair, remove bolt on end of shaft at center of motor. You may have to cut it with an angle grinder, but don't worry about that, because the shaft has to be replaced anyway. Remove motor rotor and stator. Remove washer front, drain hose, fill hose, shock absorbers, support springs, all wires attached to outer drum, and eventually the entire outer drum. Remove bolts between front and back halves of outer tub to allow removal of inner drum. Remove 6 bolts holding 3 arms of spider to back of inner drum. Re-assemble with new spider and new bolt for end of shaft. If you can do it in under two hours, give yourself a big pat on the back. This is about a 9.5 on a 1 - 10 difficulty scale for repairs on this washer.
Mar 13, 2011 | LG WM1814CW Front Load Washer
My LG M#WM2277HB wont turn the drum. It started making bearing failure type noises a couple loads ago. I just pulled it out , removed the top/back and started it. the motor rotates cw and ccw but the drum...
Oh s***! If the motor turns but the drum does not, the drive shaft has broken loose from the three arms which attach it to the drum. (the part is called the "spider") To repair, remove bolt on end of shaft at center of motor. You may have to cut it with an angle grinder, but don't worry about that, because the shaft has to be replaced anyway. Remove motor rotor and stator. Remove washer front, drain hose, fill hose, shock absorbers, support springs, all wires attached to outer drum, and eventually the entire outer drum. Remove bolts between front and back halves of outer tub to allow removal of inner drum. Remove 6 bolts holding 3 arms of spider to back of inner drum. Re-assemble with new spider and new bolt for end of shaft. If you can do it in under two hours, give yourself a big pat on the back. This is about a 8.5 on a 1 - 10 difficulty scale for washer repair. Good luck Mike.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
The washer clicks but does not tumble load in either direction... does empty out the water at the end but clothes have not been washed!
The motor coupler is broken. It's the part on the end of the motor shaft whcih connects the motor to the transmission. The clilcking is the broken motor coupler pieces colliding with each other. More info, please let me know.
Charlie
Feb 25, 2011 | Frigidaire GLTR1670A Front Load Washer
Rear dampeners through bolts are stripped
The threads or the head off the bolt? none the less, try to find a way to cut the bolt but if the head is stripped you can weld a nut and ratchet it out (works for when the bolt itself snaps) maybe a combo off cutting off the end and putting a new nut and weld it to shaft to get it out
Feb 11, 2011 | 1993 Buick Regal
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Cant remove shock absorber "bolt/pin" frigidaire frontload washer
Oct 13, 2009 | Frigidaire Washing Machines
Frigidaire front-load washer making LOUD banging noise on spin cycle. Support brace under washer tub is detached.
Does the loose brace end look broken or like a bolt fell out of it. If it has the missing bolt appearance, look for parts on the floor of the machine. Look for where it was attached and re-bolt the part. If it was welded, it will require the same to fix the problem. Not a usual DIY fix.
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Jul 12, 2008 | Maytag MAV2755A Top Load Washer
Access to parts in washing machine
2 men 2 hrs minimum tub halves are bolted together and entire assembly will need to be removed bearing is not a service part entire rear shell will need replacing and probably basket also due to shaft scoring better ck for warranty
Jun 04, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
My frigidare glws1233a top load
Do you have this noise when operating an empty machine ? It could be cause an unbalanced load of clothes. Stop the machine, redistribute the clothes and re-start the machine. In case you still have this noise, the problem is with the transmition between the drive motor and the inner tub. Good luck !
May 22, 2006 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
