Question about Gaggia Platinum Vogue 90800 Espresso Machine
Gaggia platinum leaking from milk island
My machine leaks from the centre of the milk island when coffee is brewing, it sort of bubbles up from centre nozzle. Thought it may be something to do with the island attachment so got a new one but it is still happening. Any solutions?
  • Gaggia Expert
  • 109 Answers
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Posted on Feb 22, 2010
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Looking for an english manual for Gaggia Platinum Swing Up coffee machine.
Hi
I have the original manual (a bit marked) but a better solution is to download the manual for the Swing Model from http://nettopdf.info/download.html?dl=aHR0cDovL3d3dy5jaGV6YmV0dGF5LmNvbS9pbWFnZXMvZ2FnZ2lhL2dhZ2dpYSUyMHBsYXRpbnVtJTIwc3dpbmcucGRm&t=pdf&name=Gaggia%20Platinum%20Swing%20Operation
The only difference is the manual, instead of electrical mechanism that moves the cup(s) up and down.
Cheers
Liz
Oct 07, 2010 | Gaggia 90901 Platinum Swing Up Automatic...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee maker
I think that the electric board in milk island is gone and have to be replaced. If the milk island is leaking then it goes into the milk island and you get a short circuit:-(
Mar 19, 2008 | Saeco Magic De Luxe Espresso Machine
Gaggia Platinum Vogue 90800 Espresso Machine Logo
409 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
