Question about Garden
Why does my John Deere 5425, Pto keeps shutting off?
Pto starts up and then shuts itself off about 30 seconds later. I have a cab and electric switch for pto, which cheeks out OK.
  • 708 Answers
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
Posted on May 13, 2014
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
F7 25 John Deere keep shutting off while mowing is it PTO or brake switch
the PTO an brake switch or only in the start circuit, i would look in the ignition circuit for loose connection
Aug 09, 2015 | John Deere Garden
How come I can't start my John Deere LA115 after
The Reverse Interrupt Override switch is supposed to let you keep the blades engaged while using reverse. Be sure PTO is off and brake pedal is depressed and try to start engine. If it wont start/ wont crank then a switch is stuck or failed or there is a broken wire. Switches that are involved with PTO operation are the seat switch, reverse switch, PTO switch, and RIO switch. The starting system requires neutral ( no reverse activated), brake switch and PTO switch off.
Sep 02, 2014 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
Engine cutting off after engaging the pto (mower deck) JD 317
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere gt 235 electric blade engagment but mower dies when you try to engage
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Mar 20, 2010 | John Deere Garden
John Deere sx85-engine stops with any gear selection
Park brake switch ,pto switch and seat switch will all shut down the machine,pto and park will also keep it from starting,so start at the seat.
Nov 24, 2009 | Garden
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
