Question about Faber TEND30SS300 Decorative Collection 30" Tender 300 CFM Wall Hood -
Medium Fan Speed not working
Lights, lowest fan, & highest fan all work properly. The middle fan speed does not work and does not illuminate when pressed.
  • 2,509 Answers
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
Posted on May 12, 2014
2 Suggested Answers
  • 46 Answers
SOURCE: I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
Posted on May 26, 2009
Gentlemen, I have a GE P547BS fan motor.I'm trying to replace it with a Mars 10584 fan motor.
You can check the colors on the wires with an ohm meter to find there function. Highest resistance is low speed lowest resistance is high speed the one left is medium.
Aug 25, 2015 | GE Heating & Cooling
When using the fan, we epxerience smike and burning smell on medium speed setting, but not the highest or lowest. Light have been removed to isolate where the problem comes from. Fan blades still turn,...
My concern hear is for your safety. Repairing something like this is not worth the risk of a fire breaking out or the cost of a repairing the unit. Because the problem is now in the medium setting it could go to the others as well.
Keep the light kit, but replace the fan.
Jul 02, 2011 | Oasis Hunter 54' Ceiling Fan
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
Overheating cadillac
YOU CANT BYPASS THE COOLANT FANS TO OPERATE FULL SPEED.IF YOU TRY YOU ARE GOING TO HAVE HEAD ACHES AND PCM TROUBLES.YOUR THREE COOLANT FAN SPEED IS CONTROL BY THE POWER MODULE IT ASSISTS THE COMPUTER SWITCHING FAN SPEEDS AND CLIMATE CONTROL FUNCTION.CHECK ALL 3 FANS RELAYS ONE OF THEM IS NOT WORKING.IT WILL CAUSE FAN SPEED PROBLEMS.DONT BYPASS OR OVERRIDE FANS.IF SO.YOU ARE GOING TO HAVE PCM AND CLIMATE CONTROL PROBLEMS.IF YOU HAVE ALREADY CHECK 3 FAN RELAYS.THEY ARE GOOD LET THE CADILLAC DEALERSHIP CHECK IT OUT.
Oct 04, 2009 | 2000 Cadillac Seville
2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Aug 15, 2009 | 2002 Honda Odyssey
A/c fan only works on the highest setting...not the lower ones
A/C fans only really have (2) speeds. (0)Off... and (4)On. Settings 1,2,and 3 are governed by a series of two resistors which in combinations (one, the other...then both) can limit the speed of the fan. When the circuit with these resistors goes bad, the middle speeds of your fan will cease to work. Since the highest setting is unresisted it will never stop working... unless your fan fails.
The solution is economical as these are simple inexpensive parts. For simplicity, the panel with the resistors is typically located in the dash, right behind the speed selector knob. It may be an integral component with the knob assembly depending on your manufacturer. Replace the assembly, or simply the resistors if you are lucky. On the bright note, it doesn't sound like you need to mess with your blower moter... its fine.
Cheers, unclouded.
Jul 07, 2009 | 2002 Chevrolet Tahoe
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
May 26, 2008 | Westwind Classic Hugger Polished Brass 52"...
Faber TEND30SS300 Decorative Collection 30" Tender 300 CFM Wall Hood - Logo
225 people viewed this question
Top Faber Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
