Question about Pioneer DVR-520H DVD Recorder
DVD was working fine then display screen flashes ":LSI NG", help!
It flashes in between ":LSI NG" and "POWER ON". It looks like it i trying to power up but cannot get past the error.
I actually got the same problem.
Did you succeeded to solve it ?
Posted on Apr 15, 2010
Pioneer DVR-310S LSI NG problem
I have been told LSI NG on my Pioneer 510 HDD Recorder refers to failure of the large Scale Intigraton Chip (LSI for short) so it is saying the L.S.I. Chip is No Good.
Some have commented elsewhere this might be a failure of a hard disk leading to this and to try and change the HDD out and see if the failure continues as this may cause the LSI statement...
My service tech just told me this is plausible but unlikely and the Pioneer 310/510 DVD Recorders are getting old and the LSI chips are starting to fail on them.
I regret to say the recorder is probably failing on you due to it's age. My tech commented to me these are supposedly good for five years and their current age is almost 11 years.
Remainig use life depends on the unit and how much it has been used. We got into this with a failed DVD burner on our unit which you use to burn from the HDD Hard Disk in the 510 (the 310 is a DVD Recorder only).
Just a note on servicing these units. If you remove the DVDR or HDD you then need a service remote and service DVD on these units to reset the code in the units or they will not work.
If you open them up and start disconnecting the drives and don't have these tools you will not be able to reset them and the units will not work even if there is no problem (so you have been forewarned about this).
I'd check on line for a refub unit as there are very few qualified techs to deal with these and many lack the tools for these old units. People like them because they have many great features but are no longer made. I was told all of the 510's were made within six months in I believe 2003 or 2004...
Feb 08, 2014 | Pioneer DVR-520H DVD Recorder
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Dell studio 1735 direct media lights flash nothing else
it shows power section issue of motherboard
Jan 07, 2013 | Computers & Internet
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
Can i get a display screen for a sharp microwave model # R-530ES, and if you can provide this display, can it be shipped to miami?
The relevant service manuals are HTML clipboard here and here. hey contain detailed disassembly instructions.
There are three ways to get this fixed:
1. You could order a new power unit (lower board assembly) and a new upper display board assembly, solder them together, then replace your assembly with the newly assembled one.
You'd need the following parts:
DPWBFC167WRKZ CPU/LSI/display unit $107.07
DPWBFB094MRU0 power unit $53.09
Which can can be ordered from Encompass here.
2. This option is more difficult, but cheaper. You would order the upper circuit board assembly, desolder your old one from the lower power board, then solder the new upper board onto your power board.
You'd only need to order this part:
DPWBFC167WRKZ CPU / LSI / display unit $107.07
3. You could send your control panel assembly for repair for $39.95 with a one-year guarantee. Details are HTML clipboardhere.
Aug 31, 2010 | Sharp R-530ES Microwave Oven
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
I have a PVS 1970 portable dvd player w 2 screen for our car
First, If you have a video IN/OUT switch make sure you have video OUT selected. If you have a blank but lite screen, then your display screen is bad. If you have a dark screen, you should be able to look closely and you might see an image, if so then your backlite might be out. Also make sure not to try to power dual screens with a battery. Make sure the adapter is propery rated for proper output voltage. If repair is needed, you contact me through ebay messaging. Search ebay seller " richards_resale". Good Luck!
Dec 13, 2008 | Durabrand DUR7 Portable DVD Player
Faulty power supply board
I have exactly the same problem. Indeed the power supply was defect. I have repaired it. Now the display is working but it is still not working : It displays LOADING... and that's all. Probably the controller card (the one with the LSI LOGIC chip) is also defect. It is impossible to repair, it has to be replaced.
I think this recorder is not 'CE'.
Sep 25, 2008 | Samsung DVD-HR720 DVD Recorder
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Pioneer DVR-520H DVD Recorder Logo
427 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
