Question about Delta R18000-XO Jetted ShowerTM Rough-In Valve with extra Outlet 6-
Why is our R18000-XO DIVERTER NOT WORKING
We had a plumber install the Jet Rough in Valve however when the diverter trim was put on... moving the knob doesn't change anything. Water flows from everything... all the time. There is not enough water pressure to support everything which is why the diverter is needed.
    Top Expert:
  • Delta Master
  • 45,046 Answers
The new valve diverter may be non-functional.
Posted on May 12, 2014
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
My Alpha 240E boiler does not heat water from the taps unless the radiators are on. I have been told this is because my boiler needs a new convertor valve, can I purchase a convertor valve and how wou
Its a diverter valve thats required not a converter as you state,it is not recomended to do it yourself ,you can get the valve easily from a reputable plumbers merchant ,alpha is a popular boiler, just supply the gas control no or boiler details to the merchant and the should be able to get the right divertor valve, then you just have to find a good plumber to fit it , it would be quicker and safer for some one qualified to change this.
May 19, 2017 | Water Heaters
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Final install of handle ,control valve etc.
If you but a trim kit it has the installation instructions for the trim with it. Did you open the stops to let water in?
Jun 28, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
We have a Grohmix shower valve and we are unable to adjust the water temperature. Any assistance would be appreciated.
Oct 20, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Delta R18000-XO Jetted ShowerTM Rough-In Valve with extra Outlet 6- Logo
    48 people viewed this question
    Top Delta Water Heaters Experts
    Paul Carew
    Gil Shultz
    Are you a Delta Water Heater Expert? Answer questions, earn points and help others
