Question about Dryers
Maytag med9600sq0 all lights on panel light up but dryer won't start
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
  • 262 Answers
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Posted on Jan 17, 2008
  • 659 Answers
SOURCE: Maytag electric dryer MDET446AYW no lights on
There should be a wiring diagram located where the electronics are in an envelope. Check for a fuse to the control board. Sometimes the fuse doesn't look like an ordinary fuse that we typically see on cars and things like that. It will appear to look more like a resistor. You need a volt meter to check if there isn't an obvious fuse on the control board.
Posted on Apr 18, 2009
  • 289 Answers
SOURCE: my maytag neptune electric dryer will not work the
first check that you have 240 coming to unit.than let me know.
Posted on Nov 21, 2009
rickead1
  • 1998 Answers
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Posted on Jul 04, 2011
Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Jul 14, 2008 | Maytag MED9600S Electric Dryer
How to fix Maytag dryer MED9600SQ0
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jan 26, 2016 | Maytag Dryers
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag MED9600SQ0 will not start. I have tried the following:Cleaned all vents, pulled plug from wall socket for 2 hours, and placed back in to reset;activated the - + buttons to reset the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 16, 2010 | Maytag MED9600S Electric Dryer
I have a maytage front load washer,it is stuck in control lock ,and i can't get it to do anything. the model#is mfw9800tq0. washer
med9600sq0 model #
as per maytag website=hold the "cycle signal button for 3 seconds" and it w i l l unlock. I just did it!!!
Aug 02, 2008 | Dryers
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
