Question about Refrigerators
Whirlpool ref won't get cold enough - Refrigerators
  • Chase Stiklestad May 13, 2014
    Hi Terry Pickett, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? frig should avg 37 degrees f. need model and more info
Automatic Exterior Moisture control is getting too hot on 6ED250QXDWOO 2 door side by side Whirlpool Ref
If you live in a part of the country that experiences dry winter weather, this "mullion heater" is not needed. If you air condition your home in the summer, it is not needed either. It is normal for this heater too feel rather warm, but if the freezer section is not cold enough, it will be more noticeable.
Feb 05, 2015 | Whirlpool Refrigerators
What should the knobs be set on a whirlpool side by side refrigerator
its going to depend on your usage. I would start in the middle at 4 or 5.. if breads and icecream stay frozen, and drinks are cold enough your in business, if not adjust settings I number or letter at a time giving the ref 24 hrs to stableize........... I hope this helped..... ken
Sep 30, 2014 | Whirlpool Refrigerators
16cuft top freezer and bottom refrigerator. Condenser is in the back. Both ref. and freezer are freezing. how to fix it? 2nd whirlpool refrigerator 16cuft freezer is fine but ref. is not cold?
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 15, 2011 | Whirlpool ET1MHKXM Top Freezer...
The fridge is not getting cold enough Whirlpool s20b
maybe,,your frion is not enough to refrigirate ur ref..
Aug 12, 2009 | Refrigerators
Side by side whirlpool frige, freezer works fine refrigerator section not cold enough?
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Thanks
Jul 02, 2009 | Refrigerators
Icemaker doesn't make solid cubes
The ref is not cold enough.Probably it needs super cleaning behind the panel at the back at the bottom where the fan is. Be sure to replace the back panel as it is essential to the operation of the refrig'
Also remove the front bottm plastic grate and get on the floor and clean there also.
blupkwy3
"Burke"
Jun 23, 2009 | Whirlpool ED2FHGX Side by Side...
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Question
it will be up in the panel that the cold control is mounted to the celing in the fresh food section,
remove the knobs for the freezer and the ref side
remove the frount plate that tells you how cold the settings for each side of the ref are
remove the 1/4 screws in the frount of the panel, and the ones in the rear of the panel
there you will find the cold contol
part number 2198202
May 08, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
