Question about Poulan Pro 25CC 2Cycle Gas Blower
Won't Start My Poulan Pro won't start. So I empty all the gas thinking it might be old and a silver cylinder fell out with the gas. It looks like it should be attached to one of the lines in the tank. Is this my problem?
    New Friend:
    Problem Solver:
  • 5 Answers
The silver cylinder that fell out was the fuel filter. Fashion a thin coat hanger into a small hook and try to fish out the plstic tubing. This is your fuel line. If there is enough to get it just out of the tank, cut the broken end off and press back onto a new fuel filter. You should be able purchase one at hardware store such as Home Depot or Lowes. If the hose is broken too far down inside the tank, you will need to take it to a small engine repair shop. Hope this was helpful
Posted on May 18, 2014
  • 1129 Answers
SOURCE: have poulan pro gas blower,it is geting fire but
spray carb cleaner in the carb with throttle at full then hold the throttle wide open for three pulls, if it doeasn't start remove air cleaner and put a finger over the carb hole and have an assistant or yourself pull the cord this may clear out the debree blocking the flow of gas otherwise the carb must be removed cleaned and the vacuum diaphram replaced.
Posted on Jul 15, 2009
mickey813
  • 472 Answers
SOURCE: Poulan wild thing leaf blower won`t start. Has
SOUNDS LIKE YOU SHULD GET YOU A NEW ONE ITS CHEPER TO GET A NEW ONE
Posted on Sep 30, 2009
SOURCE: I have a poulan pro bvm200 leaf blower, was
the bvm 200 model has a 25cc piston and ring the rings are infamous for getting clogged and baked into theyre seat,this creates a compwesion problem and it will not start,gets fuel spark but without compresion it'll just not run or start,if careful you can remove the piston soak it with ring atached in carb cleaner and get it springy again or replace the ring with a new one it has a 1.353 (34.38)mm bore and a ring thikness of .061 hope this helps
Posted on Nov 04, 2010
  • 640 Answers
SOURCE: Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Posted on Aug 09, 2011
  • 640 Answers
SOURCE: my poulan pro leafblower won't start, feels
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
Posted on Aug 11, 2011
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Starting problem.
Yes, that was the fuel filter. If it was loose then your fuel lines are probably bad. They will need to be replaced.
May 12, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Poulan pro bvm200vs
Take off the muffler and you should see the piston and ring..with a small pick push at ring to see if it moves. If no movement, you have carbon buildup from too much oil in fuel. Remove cylinder and carefully try to free the ring.
Jul 13, 2013 | Garden
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan pro leafblower won't start, feels like there's no compression
Aug 11, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Poulan Pro Trimmer. I don't think its getting fuel. It won't start for nothing. Can you tell me about the carburator, or some other problem? Thank you. I also need a new owner's...
http://www.poulanpro.com/node7962.aspx
GO TO THE ABOVE ADDRESS YOU WILL FIND WHAT YOU ARE LOOKING FOR.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Poulan Garden
Sep 30, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Pro 25CC 2Cycle Gas Blower Logo
110 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
