Question about Sharp AR-M205 Copier
H2 Error Message on AR M205 Sharp Copier
Does not copy or print
    Sergeant:
  • 175 Answers
Hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Posted on Jun 23, 2009
How to fix error code h2 on sharp ar-m205
"Press # - Interrupt - C - Interrupt -14 - then press start button and wait 30 seconds now task is complete" :)
Sep 09, 2014 | Sharp AR-M205 Black and White Copier
I have problem in my sharp AR- M205 Copier When i Swith On Of the Printer Then H 2 eroor on the display
H2 Trouble code is a problem with one of your thermistor. I would start by removing the fuser and then check if your thermistors are damaged or need to be cleaned. After you clean or replace use Simulation 14 to cancel the error. Perform the following procedure to enter the simulation mode. "#" key Interrupt key "C" key Interrupt key
"14" Main code Start key
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Jul 14, 2014 | Sharp AR-M205 Copier
Sharp AR- m205 error code h2
Hi
Should probably read H2-00, which is your thermistor in the fuser. Open door on right, three screws hold the fuser in (hot bit), release fuser slightly, being careful as it is still connected, the thermistor is sat in the top, you should be able to reset it by pressing the little button and you should here it click. re-fit fuser and secure.
To reset the code, press these buttons:
Hash, interrupt, clear, interrupt., enter 14, then the print button.
Cheers
Andy
Feb 17, 2014 | Sharp AR-M205 Copier
I get an E 7 message on my Sharp AR-M205 copier when switched to colour copy.
Dear, mail8 E7 has sub code please press ".key" to see the sub code .
Jan 12, 2011 | Sharp AR-M205 Copier
SHARP AR-M205, WILL NOT PRINT WITH WINDOWS 7, BUT IT DOES PRINT WITH XP, HOW DO I GET TO PRINT IN WINDOWS 7
i have window wista my sharp copier AR-M205 software is not suported in operating system please solve my problem.
Jan 02, 2011 | Sharp AR-M205 Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Power went out now my Sharp AR-M205 is coming up with code H2 how can i fixit
This code relates to temperature problem in the heating area or fuser unit . During copier warm up, a certain temperature must be sensed for it to work and it is not sensing that thus the code H2. Sort it out by keying the following codes in this sequence; Press #-*-C-* and display will go blank, enter key 14 on the panel display and press copy key. It will restart itself in a normal way. Good luck and happy new year.
Dec 09, 2010 | Sharp AR-M205 Copier
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
731 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
