Question about Whirlpool 24 in. ADP6940 Dishwasher
Wont turn on dishwasher adp951
Hi we have a adp951 dishwasher, wont turn on. Power all ok, door shuts ok, no lights come on at all when turning dial. do they have a fuse inside or any other ideas. thanks Malcolm
  • printmj Jun 23, 2009
    have taken off panel, cleaned out water from inside, tryed to reset start button but still no power. malcolm
  • 258 Answers
Ok with your dishwasher here's the most common things that are most likely stopping it from powering up, check the main power supply box, the latch switch could be bad or the motor ok now......you will need a VOM (volt-ohm meter) to check certain parts. Remember, when checking parts, the power to the dishwasher is always off, unless state otherwise, It's also helpful to keep a notebook nearby to record how things go back together.
ok.... check the power at the source. Make sure the breaker is on. If it is, then check the power at the dishwasher. If it's hardwired, go back and turn the breaker off. You will have to open the dishwasher door, unscrew the screws holding it in place underneath the countertop and shimmy the unit out. The junction box is located at the rear, on the bottom. Open the junction box and check the wires for corrosion, breaks, or loose connections. Check the interior of the box for any burn or "arc" marks. If everything is clear, turn the power back on and check for voltage by probing the black and white wires. If you get no voltage, the breaker may be bad.
If this isn't the problem, then here's a few other things to check:
  • The door latch switch may be bad -- Open the door's access panel and set your VOLTMETER to RX1. With the latch in the "open door" position, probe the two terminals. You should get a reading of infinity. Now close the latch and probe again. The reading should be zero. If not, replace the latch switch.
  • The control timer motor could be bad -- With the control panel off, disconnect the motor leads from the timer. Set the VOLTMETER to RX100 and clip the probes to the lead wires. If you get an infinity reading, or a very high resistance, then the motor is bad.
Posted on Jun 23, 2009
    Sergeant:
  • 326 Answers
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Dishwasher soap dispenser
If the dishwasher's turn dial isn't on off the door will not shut. Try turning the dial to off on the front of the washer.
May 15, 2013 | Dishwashers
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
New installation and dishwasher will not shut off
I will ask and answer some clarification questions rather than send messages back and forth. Lets see if we can get you going in the right direction.
The machine fills constantly with water. It will run even with the dial turned off.
Running and filling are two different operations so I'll make some assumptions.
There is a door interlock switch that tells the unit the door is closed and it is OK to run. That must be working or you would be dead. As is the float valve or it would turn the unit off all together.
I am going to assume from what you say it is the constant filling that is the problem. If that is so then it is the intake solenoid that is jammed in the open position or the timer is stuck in the fill position.
If it is filling with the power on or off then the solenoid is jammed. Test this by shutting off the breaker and turn on the water supply. You can also try leaving the door open. If water enters the unit for sure the solenoid is stuck open. An easy fix, remove the unit, the solenoid is located where the water supply line connects. Turn off the breaker, simply disconnect the water, power, and unscrew the part.
Depending on the unit it is possible although unlikely the the intake water supply and drain lines are reversed.
If with the power off and the water on there is not water flow then the timer is at fault.
Either way if it is a new machine then warranty should cover it.
If not a new machine you can replace these parts easily.
Check my profile and look at Dishwasher 101 tips and tricks. It explains more on how to solve and replace.
Hope this give you some direction. Please rate if so.
Mar 19, 2010 | Hotpoint Dishwashers
Whirlpool ADP951,not operating
My advice, go buy a new one. If money is tight, go to the clearance aisle at Home depot and look for a scratch/dent discount model to replace it.
Old dishwashers were never good from the beginning. No point in fixing it - it was never designed well.
Nov 20, 2009 | Dishwashers
Should you turn the dial when the door is open or
Yes, it is OK as nothing will operate unless door is closed or latched.
Sincerely, Shastalaker7
Nov 06, 2009 | Danby 17 in. DDW1802W Designer Series...
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Diswasher wont turn back on after being moved - DW Omega 908
Have you checked the door interlock switch to make sure it is not disabling the wash cycle?
Sep 01, 2008 | Dishwashers
Whirlpool ADP951 modulogic - not working
try holding down the on button for three seconds and sometimes it will complete the cycle. ours doesn't start the whole time. check your water regulator valve under your sink, as it may be leaking which may cause the problem, in the process of replacing mine, but can't find the psi value
Apr 14, 2008 | Dishwashers
Timer on dishwasher not working
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Mar 27, 2008 | Dishwashers
Whirlpool 24 in. ADP6940 Dishwasher Logo
104 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
