Question about Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows
How can I repair Windows 8.1 Windows Update, which is not working properly? I only get two optional updates for Bing, not any other updates for Windows 8.1.
  • Microsoft Master
  • 2,727 Answers
1) Run a check on your windows files
Hold down the 'windows key' (bottom row with flag) and press the 'R' key together.
type or paste in sfc /scannow
click 'OK'
Allow the scan to run and make any repairs
2) If you still have problems download some free software that may help
http://www.iobit.com/en/index.php
Download and open the Total Care software. Select 'Check for security holes' and press 'Scan'
Allow the scan to run - this will look for any outstanding updates.
If missing updates are found click on 'Repair'
Posted on Sep 16, 2015
  • Microsoft Master
  • 1,824 Answers
2 Suggested Answers
ravindave08
  • 127 Answers
SOURCE: WINDOWS MEDIA PLAYER PROBLEM TO SHOW ON LINE TV PLAYER
hi try instaling this codec pack
and if problem still arises uninstall windows media player and reinstall it
hears a link for windows media player download
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
good luck
Posted on Mar 18, 2009
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Error 8007139f
i had the same problem and my system wont work and wen i turn on my tablet it says. tablet useless now f6bc4264-7e1c-4f20-94ab-44397ef30af8.jpg
Jun 12, 2014 | Dell Venue 8 Pro Tablet Computer
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
The newest windows 8 updates
to update Windows 8:
From Desktop:
1. Tap & hold/ right click the Start button/ the bottom left corner
2. Tap/ select Control Panel
3. Search for 'Windows Update'
4. Tap/ click Check for updates
From Modern UI:
1. Swipe from right
2. Tap/ click Settings Charm
3. Choose Change PC settings
4. Tap/ click on Windows Update
Hope it helps!
-Janis
Jan 06, 2014 | Computers & Internet
Dell studio one touch screen is not working
DO NOT install Dell Touchscreen driver as it does not work with MS Touch Pack
Update Windows
Install Dell Fingertapps Touch Zone.
Install Dell Cozi YouPaint, Dell TouchCam, TouchCam Update
Install MS Touch Pack. Find here - http://forum.tabletpcreview.com/showthread.php?p=179262
Install MS XNA 3.0
Install MS Bing Virtual Maps 3D
Install Next Window Touch Screen Driver 1.3.2.5. Find here -http://www.nextwindow.com/nextwindow_support/download_confirm.html
Optional - Uninstall MS XNA 3.0, Install MS XNA 3.1
Sep 02, 2013 | Dell Computers & Internet
Windows 8 restarts after trying to connect to internet????
Please Turn Off the automati update option..then the pc willl nt restrat.......thnk u
Mar 26, 2013 | Dell Inspiron Computers & Internet
Is windows internet explorer 8 the same as microsoft internet explorer 8
Restoring Computer to earlier state is the best solution. Only update the Internet explorer by using online updates that is downloaded from Microsoft website. WebRepOverall ratingThis site has no rating(not enough votes)
Also try to update the drivers that control your PC.
If problem still occurs then use system utility tool PCFresher that will fix windows internal errors and will fix corrupt registry errors.
Dec 07, 2012 | Microsoft Windows XP Professional for PC
When i switch on my acer aspire 5735 i see a blue screen informing me that windows is updating 3 of 3 updates but nothing happens as the screen just hangs for hours? Thanks
i think your windows was updating itself but there is a problem with the update maybe you did not finish the update or the update file got corrupted. try if you can go safe mode that might fix the problem if still the same you need to reinstall your Windows.
if you are familiar with Windows installation there is an option there wherein you can repair your previous Windows installation. try that it might help before reinstalling windows.
Apr 14, 2011 | Acer Aspire 5735 Notebook
Cannot install update
Often the updates require other updates to be installed beforehand. It may also be your anti-malware solution is blocking the update from properly installing.
The easiest thing to do first, is to attempt to install the Windows updates one by one.
1. Go to your Control Panel, and open Windows Update.
2. There may be a blue link underneath the listed updates, stating that MS can look for other updates as well. DO THIS, then come back
3. Click on Optional Updates, and DESELECT all of them
4. Click on Important Updates, and DESELECT all of them
5. In Important Updates, click and choose to install the LARGEST file. This might be a .NET framework component.
6. Afterwards, and after rebooting the PC, continue with the other updates, one by one, until you find the update that doesn't install.
7. Skip that update and proceed with installing the rest of them
8. Go to Optional Updates, and install them as well in the same fashion.
9. The updates that do not install, please record and post here their KB (knowledge base) code #
Apr 13, 2011 | Computers & Internet
I have a 64 bit HP pavilion with vista home premium. When the latest automatic update occured, it shut down Internet Explorer. In order to access the web I did a system recovery and shut off the automatic...
Remove the update the caused the problem in add remove programs, then update manually, or turn off auto update. You can also install and use firefox instead of IE or try doing a repair to IE. Usually IE updates to version 8 and it has problems - version 7 works fine. Uninstalling 8 changes it back to 7. Version 8 will not download properly on a lot of sites - they changed it so U have to use Windows explorer instead to download from FTP sites, and it will not connect to some sites due to all of the security they installed. You could try using default settings on security and turn off filters to see if that works. When windows updates IE it automatically changes to high security.
Oct 02, 2009 | HP KQ495AA Pavilion A6500F Desktop PC
Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
