Question about Gaggia Baby Espresso Machine
Need to convert gaggia baby from capsule use to regular coffee
Need to convert gaggia baby from capsule use to standard coffee as problem with obtaining capsules.was told this was possible.
  • Anonymous Mar 14, 2014
    Looking for the small rectangular hole to push down on switch housing to release housing
    President:
  • 1,618 Answers
Yes, as far as I know most machine that use pods just have a different portafilter, because of the way the pods are setup.
Posted on Jun 24, 2009
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Gaggia Baby Ivory, 2 weeks old.Hot coffee spurts out of side of brewing head when brewing. I called your Philips help line & was told that I had to insert a plastic disk, which is not shown on the...
If coffee is brewing out the side of the head then the group gasket needs to be replaced because it is damaged or there might be coffee grounds stuck to the gasket and it needs to be cleaned using a brush or you can also use cotton swabs.
May 23, 2011 | Gaggia Baby Espresso Machine
My baby gaggia is putting out water too fast resulting in weak coffee.
Adjust the coffee grinder to finer. (coffee grounds are too coarse)
Jan 17, 2011 | Gaggia Baby Espresso Machine
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
My capsule / pod holder is broken. Where can I get a new one, and how much do they cost ? Thank you
hi,
contact ylavoie@sybco.com. they are located in canada and are the distributor for caffitaly. they have a model called ocs3000 that has exactly the same capsule holder.
ciao
Sep 26, 2010 | Gaggia Caffitaly K111 Coffee Maker
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
? Am I trying to use coffee ground TOO FINE
On my Gaggia Machine I use an Gaggia MDF Grinder on 8 or 9 setting for the best flow. I only use as low as 4 with my Presso Manual Machine
Nov 05, 2008 | Gaggia Classic Espresso Machine
Baby Gaggia White Color
If you take of the top then you can see the boiler, on the top of the boiler you will see thermostat in the middle on one you will see a little pin, press down the pin to reset.
Jun 29, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Baby Espresso Machine Logo
185 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
