Question about HydroSlide Phantom Kneeboard
Install kneeboard in inflable boat
Hi, i want to know how can i do to install my phantom in my boat inflable, it has a mirror but doesn`t have a hook to put the cord. Thanks.
U have a 1971 15 ft phantom bass boat tri haul , the tag is missing , how big of motor will it handle legally ?
I had a 1976 15 ft checkmate. Low sides. It was rated at 100 hp. A 100hp in those days was pretty big. My 90 was a 6 cal merc. Todays motors are much smaller for the same ratings. A 75-90 3 cyl should work nicely and be safe.
Sep 19, 2014 | Boating
Tip
Getting up on a Kneeboard
One of the biggest problems I hear from new kneeboarders is that they have a really hard time getting up on the board. There are two methods that I think will help you to get up faster and spend less time falling down.
The first method you start by laying on your stomache on the board while the driver of the boat starts the boat slowly. You want to keep your head slightly up with your arms bent and your forearms on the board. When the driver starts moving the boat it will pull you up, once you have picked up a little speed you want to pull yourself up all the way to your knees with your nose aligned with the end of the board. If you find that the board is jumping you are either too far down on the board or the boat is going too fast.
When you feel that you are ready to get all the way up, grab the tip of the board while still holding the handle and quickly pop up. If you don't get all the way up by popping like this you can inch your way up slowly.
The second method is to start out on your knees. This way can be very difficult for a beginner so if you don't have good balance you might want to stick with trying the first method.
Start in the water with the board in front of you, grabbing the tip force the board under water and under your knees. Keeping the board under you, make sure to keep the board parallel to the water until the rope has been pulled tight, then you want to lean back just a little so that the tip comes up. Once you are balanced and up on your knees you are ready to go.
It is recommended that you practice this maneuver in a practice pool or in shallow water before getting into open water with a boat.
on Jan 06, 2014 | Water Sport
Is there any safety rules to tell my kids when they go out tubing relating to tow cables?
  • Make sure the person you put in charge of the rope knows how important their job is.
  • Always keep a toolbox on board with a knife to cut lines / ropes. You may want to start shopping atToolSource.
  • When in salty water swimming a boat out of shallow water wear shoes in case you come across an oyster bed.
  • Keep a marine first aid kit on board to patch feet cut on oyster beds.
  • When your kneeboard/wakeboard rope is cut or broken you can use a regular ski rope and just shorten it. It works like a charm.
taken from http://waterski.about.com/library/weekly/aa060198.htm
Feb 20, 2013 | Water Sport
What do you use in kneeboarding to secure yourself to the deck?
You should secure yourself using a Velcro strap that can be adjusted that goes over your thighs.
Feb 14, 2013 | Water Sport
Do i need to use the strap when kneeboarding?
you don't NEED to, but if you want to jump, or if the water is choppy, or you just hit another boats waves, it will really help you stay on.
Jan 20, 2013 | Water Sport
How do i get up on a kneeboard?
start on your stomach. the driver should start to pull slowly, not fast like with a skier/wakeboarder. while you are going slowly on your stomach, plant your elbows and gradually pull your knees up and into the knee indentations
Engine cuts out while running
Sounds like a coil pack getting hot and breaking down
Aug 07, 2009 | Boating
My microphone doesn't do it right.
Some of the Podcast mics are condenser mics and MUST be used with a preamp or DEVICE that supplies PHANTOM power to the mic.
You computer DOESN"T supply Phantom power.
Read up on Phantom power in Google to understand it.
Apr 03, 2009 | Behringer XM8500 Professional Microphone
HydroSlide Phantom Kneeboard Logo
217 people viewed this question
Top HydroSlide Water Sport Experts
Tom Chichester
Bill Boyd
Are you a HydroSlide Water Sport Expert? Answer questions, earn points and help others
