Question about Dishwashers
Where can I buy replacement dishwasher racks for an ancient machine?
Rack question.....we have an ancient dishwasher - which is integrated and still works perfectly (though obviously I've jinxed that now!). The model number/make is: Philips Whirlpool DW721/1 w .........really could do with replacing the upper and lower racks due to rust.....is there any chance these are a) available or b) would current model racks fit? Thank you x
  • 51 Answers
The racks are probably no longer available new but if you check with appliance repair shops they shouls have something that will work because several brands are made by the same mfg and parts wioll interchange.
Posted on May 12, 2014
alumaguy
  • 3 Answers
SOURCE: Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Posted on Mar 16, 2008
SOURCE: Our Maytag dishwasher, mod MDB9150AWS,
Yes, I resolved the problem after thoroughly studying the assembly. It was relatively simple; all I had to do was turn the spray tower 90 degrees and it came free of the rack.
Thanks for the web site, nonetheless.
Posted on Aug 28, 2008
  • 10865 Answers
SOURCE: Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Posted on Feb 14, 2009
SOURCE: model gu2700xtss1, upper rack not clean at all,
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
Posted on Feb 22, 2009
  • 423 Answers
SOURCE: LG dishwasher does not seem to clean items on lower rack
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Posted on Mar 30, 2009
How do I remove the top rack?
Good Morning friend, thank you for your post!
Based off what your have described you need assistance in removing the top rack off your Electrolux dishwasher. In order to remove the top rack you would need to remove the caps from your rail and you should be able to pull it up and out. I hope this information is helpful. -Matt
Feb 21, 2015 | Electrolux EWDW6505GS Fully Integrated...
How do I reset my Kitchenaid dishwasher that is blinking the clean light 4x
This post is saving me from buying a new dishwasher!! Thank you so much!! It hasn't worked in months
Apr 24, 2014 | KitchenAid Superba Architect II KUDE60FX...
We have got the machine for approximately 2 years and the top dish rack has corroded so badly that I think it might collapse with a load on it. What could be the cause of it?
The causes are usually poorly coated rack combined with rough usage (coating pierced
by cutlery, broken stemware, etc., combined with hard (mineral-laden) water, which
corrodes the steel of the rack quickly.
Luckily, the upper rack is replaceable, so check:
http://www.buyspares.co.uk/dishwasher/ld12bw5/basket/catalogue.pl?shop=lg&path=111329&model_ref=49220&refine=basket
Jun 09, 2011 | LG 24 in. LD-12BW5 Free-standing...
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I have a GE profile dishwasher. The wheels on the lower rack have all come off and I can't seem to get it back on. On some, the piece that snaps to the rack is either broken or melted off somehow. Do I...
You just need the wheels. I have bought the upper rack wheels before, now I need the lowers. I have found a site selling them at 10.00 each. I am going to keep looking, I think I can do better, considering I need 4. I might just buy a new washer if I have to spend 40.00 plus shipping! I will post back if I find a better deal.
Jan 08, 2011 | GE Dishwasher Lower Rack Roller WD12X10262
Wheels keep falling off on lower rack, clips all
the clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Nov 17, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher rack rotting
Depends on the age.
Eventually dishwasher racks deteriorate.
It is rusting from the inside out.
Replace the rack.
Mar 12, 2009 | Whirlpool 24 in. DP840D Free-standing...
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
