Question about Olympus Stylus 710 Digital Camera
Confused.... am i facing the lenses? or the lenses are facing the ceiling? which is which????
  • 30 Answers
What???
The lens is considered 'facing' towards the source of the image. The camera body / sensor / film is considered to be 'behind' the lens.
you are facing the lens when the camera and lens is in front of you, regardless of where the camera is aimed.
The lens is facing the ceiling if you point it upward as if to take a picture of the ceiling, regardless of where you are facing.
Posted on Jan 28, 2010
How do I make these Snapchat lenses work?
    1)Get your snapchat app updated. Visit the app store, hit updates from the bottom right, and presto.
    2)Now, go to settings on your snapchat home screen and turn "filters on."
    3)Open latest version of app and make sure your face and make sure your front facing camera is active. Now long press the screen on your face to load the lenses. You can scroll horizontally through them and for most you'll need to follow an instruction for it to work properly such as opening your mouth or raising your eyebrows.
    4)Get your selfie face on. Lenses
      1)Camera screen
      2)If your rear-facing camera is active, switch to Selfie camera.
      3)Press and hold on your face! Lens options will appear below
      4)Swipe left to select the lens you want to use
      5)Follow any action prompts that appear
      6)Tap capture button to take a snap, or press and hold on the capture button to record a video.
How to use Snapchat lenses filters update 2015 Got your selfie face on
Sep 17, 2015 | Computers & Internet
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
Camera switches itself off unless the viewing screen is closed.the camera will still take shots using the viewing lense but will shut off immediately if the screen is opened.
This behavior comes when the camera is confused about whether the flip-screen is snapped into the camera screen out or screen in (for protection). The screen is supposed to turn off automatically when you snap it into the camera-back screen down. But if you flip and twist it in a certain way, the camera gets confused. I'll bet that if you keep your screen out, on the side of the camera, you can take pictures just as well as ever. To fix the problem, flip the screen out with the camera on, then rotate it all the different ways you can which allow you to close it with the face out. One of the orientations will leave the screen on, I believe. At least this procedure is the one I followed on my A610 to fix the same problem.
Mar 30, 2010 | Canon PowerShot A610 Digital Camera
300mm lens #37614970 what camera does it fit on.
K/AR is a konica mount (not to be confused with Pentax K mounts) - see article
http://photo.net/sony-minolta-slr-system-forum/00UmBi
Usually on Vivitar lenses the last 5mm of mount can be changed / interchanged. What you probably have is the univeral lens, with a Konica K/AR mount.
Feb 27, 2010 | Vivitar Cameras
What is the little red box in the upper right had corner of the window when I click on a effect?
I had the same problem and accidentally stumbled into an answer.
Many of the effects require the software to identify your face by locating your eyes. I was wearing glasses, and the reflection of the monitor in the lenses was confusing the eye recognition algorithm.
I simply removed my glasses and the software applied the effect. Interestingly enough, once the effect was working I could put my glasses back on and the software was still able to track my eye location.
Dec 17, 2009 | Microsoft LifeCam VX-5500 Webcam
Won't turn on. . Lense appears to be jammed
throw it on your bed lens face down 3 times and 1 time faced up to release the lens lock.
May 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
Tasco Model 59T additional lenses
Do you mean eyepieces? If so, they are either .965", 1.25" or 2". I'm betting yours are .965" or 1.25" which is a standard and you should be able to fit anyones same-sized eyepieces in the focus housing. Measure the diameter and you will know.
If you mean lenses, then the question is confusing, as you increase or decrease power by switching out eyepieces, not objective lenses.
Look on eBay for eyepieces and you'll find plenty.
Aug 09, 2008 | Optics
Error code 5e02
Thanks for the tip! Had the same problem, worked for me too=)
Apr 10, 2008 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
