Question about Blenders
Vitamix 3600 manual
I need to replace the toggle switch on my 3600. Its a Carling but has no part number, there are so many switches out there. Any idea on what specific switch I can buy to replace the broken one?
  • 1,566 Answers
Get a switch with the same or higher voltage and current rating, and similar mounting and terminal connections. If you can't find the rating on the switch itself, use the nameplate rating on the appliance label.
Once you have these numbers, go to the Carling Tech toggle switch page and drill down through the selections to identify what you need. Toggle Switches
Posted on May 12, 2014
The drive stud on my vitamix 3600 blender sheared off. When screw is replaced it comes unscrewed when the blender is turned on. Does anyone know if the original design included epoxy weld?
If the motor runs in reverse to an Oster which uses counter clockwise thread then it follows that your thread should not be counter clockwise. If it comes loose when you turn it on surely the thread on the coupling must be faulty because according to your description the action of turning it on can only be to tighten the coupling. Most couplings with a thread that I have seen are counter clockwise so you will probably struggle to find another brand coupling to match.
Feb 28, 2015 | Vitamix Blenders
Vitamix 5000 Why does it run only on high ?
It very likely needs a new pot switch. That is the rotary one that varies the speed. Purchase through your local Vitamix service agent in your country.
Jun 05, 2014 | Vitamix 5000 Work Top Blender
On my Vitamix 5000 the variable speed control does not work
It will probably just need the pot replacing, take note of where the wires go. I see someone else here is doing the same job and wants to know where to put them back. Take a photo first saves a lot of grief. The pot is the rotary resistance switch behind the knob.
Mar 24, 2014 | Vitamix 5000 Work Top Blender
Vitamix 3600 throws sparks when turned on
Sounds like it may need a new blade/bearing assembly or coupling or both.
Feb 25, 2014 | Vitamix Blenders
Where can I find a motor
Vitamix says they will fix units up to 20 years old or so????
check here:
Contact Us Customer Service Vitamix
Don't know about 30-40 years old????
good Luck
Feb 23, 2014 | Vitamix Vita-mix 3600 / 4000 Handle For...
Need to replace speed control
They are called a "Potentiometer" or Pot for short.
Variable Speed Control Switch
check here:
vitamix potentiometer
Feb 19, 2014 | Vitamix Blenders
Loosened blades on a vitamix 3600 stainless steel container
If what you can't see in your device, namely the motor assembly, it may be that the assembly is one of those not designed to be taken apart and that it is wearing out. If so, that could be the cause of the looseness you are experiencing. It may be unrepairable or more costly to fix than to replace. Twenty plus years is a good run for almost any mechanical device.
Jan 02, 2014 | Vitamix Vita-mix Super 3600 Stainless...
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
Need a manual for my Vita Mix 3600
Here is the only online use and care maunal available : http://kitchen.manualsonline.com/manuals/mfg/vitamix/advance_performance_beverage_blending_all_models.html
You can click on get manual after a script window runs asking you\ questions... You don't have to answer or provide an email address! (just close it) Then click Get Manual and once it opens.... save it to your computer.
Jan 19, 2010 | Blenders
Blade not spinning
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
May 28, 2008 | Vitamix 36000 Work Top Blender
Blenders Logo
94 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
