Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
About security I want to secure a wireless network,so i was go on security & select the wep option & type in phrese password.Afer that we connectt wireless is connect but not brows.SO plz write me which option i have selected so my wireless network will be secured.
  • 630 Answers
Remember you have to do this at both the router and the computer which wirelessly connects to it.
Posted on Jun 23, 2009
    President:
  • 1,383 Answers
Check that you havew enavbled dhcp srver.
if your computer get automatic ipadreses.
Check in your computer "ping yahoo.com" if you get reoky then your intenet is working fine then check your computer fireweall and antivirus firewall settings.
How do I enable WEP encryption
Configuring WEP on the router First, let's log on to the router.
  1. Open your internet browser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. In the login box that appears type 'admin' (without quotes) in both fields. 'admin' is the default username and password.
Write down the SSID
  1. In the Wireless > Basic Wireless Settings menu you will see the Service Set Identifier or SSID. The SSID differentiates one wireless network from another. It is the 'network name'. Write it down, or copy paste it to a text file. You will need it later. You can first set your own SSID if you like.
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
'WRT54G The Wireless Security page allows you to generate a strong network key. Here is how.
  1. Select WEP in the security mode dropdown menu.
  2. Set the Default Transmit Key to 1
  3. Select 128 bits hex digits from the WEP encryption dropdown menu.
  4. Enter any phrase or word in the Passphrase field and press the 'generate' button. The passphrase is just used to generate keys. It has no other purpose.
  5. Copy-paste the first key to a text file or write it down.
  6. Click Save Settings.
Your computer will now be disconnected from the router. You may see a 'page not found' warning or some other error message in your webbrowser. Your router now demands that computers that connect to it use WEP encryption and the correct WEP key. In other words: you have succesfully secured your network.
Mar 18, 2011 | Linksys Wireless-G Broadband Router
Tip
Wireless Part Configuration of Belkin routers without CD
Wireless Part Configuration:
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Step 1: Wi-Fi Protected Setup (WPS)
In the Belkin router Setup page, on your left hand side, you may have Wi-Fi Protected Setup (WPS) below WIRELESS. If you have WPS then click on it. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be Enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
Select Security found on left side of router setup page.Security mode will have the following options,
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Usage of above security modes for various devices:
  • WPA / WPA2 (PSK) ------for vista & windows7 computers
  • 64-bit WEP -------for windows XP, MAC, XBOX, Play Stations, Ipods, Ipads (recommended)
  • 128-bit WEP ------same as 64bitwep, but not recommended
  • Disabled------to disable the wireless security
Disabled: If you think there is no need for security for your Wireless network or if you are willing to make it as a hot-spot then you can select the option as Disabled and Click on Apply Changes.
WPA/WPA2: If you are selecting the Security type as WPA/WPA2 then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
64bitWEP: If you are selecting the Security type as 64bitWEP then you will be able to see the Key 1 with 5 empty boxes. You need to type 2 numbers in each boxes of Key 1. You can also use letters A-F along with numbers 0-9 to make your password more secure. Password is case sensitive. After filling those details click on Apply Changes directly. You must not type anything in Passphrase and click on generate. If you do so, it will generate a password automatically.The 10digit value which you entered in key 1 is the password for your wireless network.You need to enter the same password without any spaces in between in your computer to get connected to your wireless network.
128bitWEP: If you are selecting 128bit WEP, then you need to follow the same instructions as above but you need to enter 26characters in 13 empty boxes.
Step 3: Channel and SSID:
  • Once you are done with that, select Channel and SSID found on the left side of RSP.
  • Change the Wireless Channel to 1 or 6 or 11 (these are the best non- overlapping channels for wireless networks).
  • Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
  • Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
  • Once you are done click on Apply Changes.
Now the Router is configured for wireless devices.
Connecting your wireless computer to the wireless network:Make sure the wireless switch is turn on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected.
on May 05, 2010 | Computers & Internet
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
How do i password my wireless router
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Sep 10, 2010 | Computers & Internet
How do I set up a password to secure my wireless network
Aug 08, 2010 | D-Link DI-634M Wireless Router (DI634M)
I cant secure my wireless network. a website told me to type in 192.168.0.1 and it brings d-link page and tells me to type in a login name and password. The back of my router tells me to type in "admin"...
Jun 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do I obtain my own WEP Key?
Hi Friend,
Please follow the steps:
1.Open router page(192.168.0.1)
2.Enter the username and password.
3.Click Wireless settings.
If you have configure the password you can see it in this section or else you can configure the passwword as mentioned:
Name(SSID)-As per your choice
Region-As per your location
Channel-1
Mode-you can select g only (if u have a G wireless adapter)
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption-64
Security Key
Key1-Type a 10 digit or 10 letters password(like your telephone number)
Click Apply and turn off the router for 30 seconds.
You have a secured network now.
Regards
Chiranjeet
May 23, 2010 | NetGear WGR614 Wireless Router
How do I secure my network
May 18, 2010 | Arris SURFboard SBG900 Wireless Router...
WEP password for Westell 327w
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;} Slide 1 .O {color:black; font-size:149%;} .O1 {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC !important;} a:visited {color:#B2B2B2 !important;} Open Internet Explorer & in the URL:// bar type: 192.168.1.1 or dslrouter.
Select Wireless and then select Security from the Configuration
menu.
If you use WPA-PSK or WEP
wireless security, you must configure your computer’s wireless adapter for the security code that you use.
At the Wireless Security drop-down menu, select the desired security option
WEP: Selecting this will enable you to set up WEP security on the VersaLink. The AP card
supports 64-bit, 128-bit, or 256-bit WEP encryption. If WEP is selected, any station can connect to the AP (as long as its SSID matches the AP SSID). If wireless security is disabled, the risk of someone nearby accessing the AP is maximized
type in the desired WEP Password....do not forget to save...
Oct 27, 2009 | Westell Wirespeed VersaLink...
How can i make my wireless router connection secure? i mean for other people not to get my signal.
You need to set up network security on both the router and the computers you connect to it. Log in to the web settings page (probably https://192.168.0.1) for the router and you'll find a security tab.
Oct 03, 2009 | NetGear RangeMax WPN824 Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
80 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
