Question about Swiss Gear SwissGear Queen Raised Double High Air Mattress with Built-in-Pump
I got a Swiss gear queen size bed ans it's got a hole right on t he top of the bed on a seam, the patch that came with it is not working in sealing the hole, what else can I use?
  • 63 Answers
You could try some seam weald glue.
But when these leak from a join, it can be very very hard to reseal them.
You could try a hot soldering iron, carefully try to reseal.
But to be honest it may be easier to purchase new.
Posted on May 13, 2014
Tip
How to locate a leak in a waterbed and repair it
Finding the source of a leak in your waterbed may not always be easy. Some punctures can be very small (some even the size of a pin), making it difficult to find. The best place to start is by wiping the entire mattress dry. Before going any further, make sure that your heater is unplugged. First try to locate the leak without draining the bed. Place paper towels around the perimeter of your bed as well as around the corners and bottom seams. Then lay on your bed for a minute or two to apply some pressure. Check the paper you laid down to help diagnose the location of the leak. If this method does not work, you may have to drain your mattress. Refill the mattress with air and sit on it. Using a spray bottle filled with water and dish soap spray the suspected areas. You will see bubbles appear in the area where the hole is located.
Once you have located the location of the leak, you can now repair it. You will need a vinyl repair kit - most waterbed mattresses are sold with one, if not I will leave you a link so that you can purchase one online. For a small pin-size hole, you will only need a very small patch. Try to cut either a round/oval shaped patch as corners usually lift. Apply some adhesive to both the patch and the mattress and attach. You should let the patch dry for a minimum of two hours before putting any pressure on it.
http://www.waterbedoutlet.com/Waterbed-Vinyl-Repair-Kit-p/wba-blu597300vrk.htm
http://www.amazon.com/Blue-Magic-Waterbed-Vinyl-Repair/dp/B004J6NFYY
on Aug 28, 2012 | Furniture
What sized beds are typically found in hotel rooms?
In hotel rooms, you usually have the option ofchoosing between queen and king d bed as the main bed in the room.
Jul 30, 2012 | Furniture
What are the standard sizes of beds?
Standard bed s are twin, long, full, queen,king, and California king. For a complete list of the dimensions of thesebed s, go to these website: http://interiordec.about.com/od/beds/a/beds.htmand http://www.fortywinks.com.au/beds-mattresses/bed-.html
What is an air bed?
An air bed, also known as air mattress, is aninflatable mattress (usually by hand). These beds are mainly used at home forguests and come in standard s (queen, king)
What is the difference between a king size (eastern king) mattress and a California king size (western king) mattress?
I found you a great comparison chart that shows the differences between the two types of mattresses.
chart
California King Size
King Size
Usage:
California King Size beds may be found either in the master bedroom or for exceptionally tall kids.
King size beds are usually found in the master bedroom.
Cost:
California King Size beds cost roughly the same as regular king size beds.
Since a king size bed is larger, it is more expensive and mattresses in this size may also cost more compared to queen beds.
Width per person:
The width available on a king size bed would be 36 inches per person if two people are sharing it.
The width available on a king size bed would be 38 inches per person if two people are sharing it.
Space economy:
A California King size bed is larger than a queen size bed. It is longer but narrower compared to a regular King Size bed.
A king size bed is fairly large compared to the queen or full sizes.
Length:
84"
80"
Width:
72"
76"
Surface area:
6,048 sq. in.
6,080 sq. in.
Chart was taken from: http://www.diffen.com/difference/California_King_Size_vs_King_Size
Jul 25, 2012 | Furniture
Water leaking unto front floor carpet when driving through rain
Check around the edges of the windshield for any place water could be forced into the car. Especially if the windshield has been replaced. Check around the cowl that covers your windshield wiper motor. Remove the cowl if possible to check for rust holes or separated seams in the metal. The blower motor intake for the cars HVAC (heater) is often under this cowl. Make sure water isn't getting in through there. If you find a leak around the windshield or a separated seam, some windshield urathane or clear bathroom caulking would work. If you find a rust hole in a non visible place affix a tin or metal patch over it using rivets or your choice of fastener. Welding is the best method. Then cover the patch with short strand fiberglass bondo or something else to seal out water. If you have a hole in the floor you could put a patch on it with rivets or weld, then tar the underside well and put rocker panel coating on the top.
Sep 20, 2011 | Toyota Corolla Cars & Trucks
What is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Sep 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Swiss Gear SwissGear Queen Raised Double High Air Mattress with Built-in-Pump Logo
636 people viewed this question
Top Swiss Gear Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Swiss Gear Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
