SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
SOURCE: Belling DB3 Duek Fuel Cooker
Above the door on the oven frame thre is a sliding retaining plate held by a screw in a slotted opening. Release this screw and slide the plate to the right (for the main oven door) then the door can be lifted out. Once the door is out the glass can be slid out for cleaning. Be careful to replace the the glass face in the correct direction to the oven. Hope this is helpful.
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
SOURCE: Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
SOURCE: old belling classic cooker,oven door catch has
my oven done the same so i bought some strong magnets and put one in each corner.
its fine now.
