Question about Kyocera Mita KM-2050 Printer
Kyocera km 2050 drum reset - Kyocera Mita KM-2050 Printer
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 245 Answers
Press10871087 after counter reast all
Posted on Dec 24, 2014
  • 36 Answers
SOURCE: kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Posted on Apr 08, 2008
  • 66 Answers
SOURCE: I have Kyocera Mita KM-2050
you need to get the i.p address of your scanner and access it from your browser.
on the bottom left of the command centre menu you will see SCAN TO PC  "destination" .
put your details in new screen. if you are using a static i.p address for your pc put that in.
if you are running dhcp you should use the host name of your pc
Posted on Mar 10, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
  • 62 Answers
SOURCE: Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Posted on Feb 01, 2010
Lost the pin code for kyocera 2050
The default code for the Kyocera KM-2050 is 6482.
Jun 30, 2015 | Kyocera Mita KM-2050 Printer
How to reset all originals in DP Kyocera km 2050
It just means take all the pages out of the document feeder on top and put the whole complete document in again
Jun 14, 2015 | Kyocera Mita KM-2050 Printer
HOW i CAN FIX THE ERRO C6400
press10871087 after press163 reast
May 09, 2014 | Kyocera Mita KM-2050 Printer
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
Kyocera Mita KM-2050 Printer Logo
113 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
