Question about OKI PRINTER,MB451W,120V,BG
WHO DO I CLEAN PRINT HEAD OKI MB451W - OKI PRINTER,MB451W,120V,BG
  • 1,606 Answers
The MB451W uses electrostatic toner and does not have print heads. Follow the cleaning instructions beginning on page 172 of your User's Manual. If you don't have it handy, you can download it from the OKI website. (The link is for the English language manual.) http://my.okidata.com/mandown.nsf/196efed9e03ff0d1852576ee00476710/3854f93fb3d0181185257a7f004eddcb/$FILE/MB461_MB471_MB471w_MB491_ES4161%20MFP_ES4191%20MFP_MPS4200mb_Basic_UM_E.pdf.pdf
Note: on page 174, the manual recommends "soft tissue paper" for wiping off the LED array lens. Lens-cleaning paper or cloth for plastic lenses should work and is less likely to leave lint behind.
If you are getting random black blobs on the back of your printout after cleaning the printer as recommended, the fuser is dirty. If the fuser cleaning strip is accessible (a felt strip that wipes off the fuser roller during operation), gently scrape it clean with a knife blade held perpendicular to the strip, then clean the debris out of the printer. (CAUTION: the printer must be off long enough to be cold before working on the fuser!) If you can't get into the fuser, use the following procedure: Get matte-finish paper of the thickest stock your printer will handle. Put several sheets of this paper in the paper tray. At the computer, type a single space on a blank document, with no headers or footers, then print the blank page (trying to print with nothing at all usually doesn't work). This should pick up some of the trash. If you still have problems, open a graphics program and draw a solid black rectangle all the way across the page ("portrait mode") and about 4" high. Place a copy of this rectangle 2" below the first one. Insert a page break, and put a white object (anything white or transparent, with a white boundary) on the second page. Print double-sided. The black rectangles will pick up dirt from the fuser roller and the heat will make it stick to the paper toner. Repeat if necessary, then remove any unused cleaning paper from the tray.
Posted on May 12, 2014
How do i clean the print heads on a oki c5200
With the top cover open, gently wipe the LED head(s) with the lens cleaner pad supplied with replacement toner cartridges. A soft, lint-free cloth with some isopropyl alcohol (rubbing alcohol)** can also be used.As the last step before closing the cover when replacing a toner cartridge or an image drum.
If you are experience poor print quality, including
- longitudinal white stripes or fading
- blurred letter edges
CAUTION! Do not use methyl alcohol or other solvents on the LED heads: this will damage the lens surface.
Nov 21, 2011 | OKI C5200n Laser Printer
Oki fax 5050 cleaning
There is a option in the OKI for maintence. Look for this option in the menu. Clean the drum and toner there
Feb 15, 2008 | Office Equipment & Supplies
Does not print clearly
Remove the print head if you are able to do so and clean it. If you can't remove it ... clean it as best as you can. There are cleaning products available for this procedure ... I have had success with WD-40 ... but am not specifically recommending you use this on your printer.
Thanks for your visit today.
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Can't seem to get anything to print everything hooked up OKI c3300
Check to see if the toner is finish and also check to see if the papers are correctly place into the printer.If the paper is not push into the printer properly the printer will not be able to grab the paper and you can also clean the print head on the printer. .
Aug 14, 2010 | Oki Electric Industry C3300n Laser Printer
My oki 320 prints with a gap in each letter how do i solve this
If the missing spot is always the same it sounds like a broken pin in the print head. If this is the case you need to replace the print head.
Feb 18, 2010 | OKI MICROLINE 320 Matrix Printer
How do i clean my okidata b4350 printer.The print is too lite.
On board menu.
Access and go through menu click print head clean. Or reinsert disc should have extra faciliies.?
Nov 08, 2009 | OKI B4350 Laser Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
OKI MICROLINE 420
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
Oki 320 turbo alarm light
check the mesage in your operating mannual
Sep 13, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI PRINTER,MB451W,120V,BG Logo
584 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
