I am getting this error after making some several print outs, PCL XL error Subsystem: TEXT Error: illegalfontData Operator: Text Positin: 324223
  • 92 Answers
CAUSE: This error is usually caused by an issue with communication or an incompatibility between the Enhanced XL language and the software application that is associated with the file being printed.
WORKAROUND:
After attempting each item of the suggested workaround listed below, try to print a page using the software application or document in question. This will help determine if the changes made have caused the desired results to occur.
Item # 1
Connect the printer directly to the computer. Use an IEEE-1284 compliant cable. Try different IEEE-1284 compliant cables.
Item # 2
Use the control panel on the printer to turn off "High Speed" and "Advanced Functions" by performing the following steps:
a. Press the MENU key until "I/O MENU" appears in the printer display.
b. Press the ITEM key until "Parallel High Speed = Yes" appears in the printer display.
c. Press the VALUE key until "Parallel High Speed = No."
d. Press the SELECT key. An asterisk should appear in the display to the right of the message "Parallel High Speed = No*."
e. Press the ITEM key until "Advanced Functions = On" appears in the printer display.
f. Press the VALUE key until "Advanced Functions = Off."
g. Press the SELECT key. An asterisk should appear in the display to the right of the message "Advanced Functions = Off*."
Item # 3
Access the properties of the appropriate PCL6 printer driver by performing the following steps:
Windows 95
a. Click the "Start" button in the lower left hand corner.
b. Select "Settings" and "Printers."
c. From within the "Printers" window, place the mouse pointer over the printer icon, picture, or description, and press the right mouse key.
d. From the drop down menu, select "Properties."
e. In the window that pops up, click on the "Details" tab.
f. Click the "Port Settings" button located near the bottom of the window.
g. Click any check marks in the boxes to remove them.
h Click the button marked "OK".
i. This should return to the screen associated with the "Details" tab.
j. Click the "OK" button at the bottom of the screen to return to close the "Properties" windows and return to the windows desktop screen.
Windows NT 4.0
a. Click on the "Start" button in the lower left hand corner.
c. From within the "Printers" window, place the mouse pointer over the printer icon, picture, or description and press the right-mouse key.
e. In the window that pops up, click the "General" tab.
f. Click the "Print Processor" button located near the bottom of the window.
g. Select "RAW" if it has not already been selected.
h. Click on the button marked "OK."
Item # 4
Set the printer port to LPT1: (printer port).
a. Place the mouse pointer over the icon labeled "My Computer."
b. Press the right mouse key and select "Properties" from the drop down menu.
c. Click on the "Device Manager" tab.
d. Click on the "+" sign to the left of the "Ports (COM & LPT)" item listed under "Computer."
e. If "ECP Printer Port LPT1" is listed check the PC documentation for instructions or call the PC manufacturer for assistance in changing the printer port to "LPT1: (Printer Port)."
Item # 5
Update the version of the LPT.VXD currently on the system. To identify the current version of the lpt.vxd file in use on the system, perform the following steps:
a. From the Windows 95 desktop, select Start, Find, Files, and Folders.
b. In the "Named" area, type: lpt.vxd.
c. Select Find Now.
d. Once the file is located, right-click the filename and select Properties.
e. Select the Version tab. Contact the manufacturer of the personal computer for information on obtaining the most current version.
Item # 6.
Isolate the driver from the Windows (NT or 95) operating system.
a. Open the application in question.
b. Select "File" then "Print."
c. In the upper "Printer" section, below the "Properties" button, a checkbox is located.
d. Click the check box to the left of "Print to File" and verify that a checkmark appears.
e. Click "OK."
f. Select the "C:\Windows\Temp" directory and name the file "Test."
g. Click "OK."
h. Close all applications that are open.
i. Click the "Start" button in the lower left hand corner of the desktop.
j. Select "Shutdown" from the menu.
k. Click the radio button to the left of the selection "Reboot into MS-DOS mode."
l. When the computer reboots, something like "C:\WINDOWS>_" should appear on the computer screen.
m. At this "C" prompt, type "cd\Temp."
n. From this prompt, "C:\WINDOWS\TEMP>_", type "copy test lpt1."
o. This should copy the newly created file over to the HP LaserJet Family Printer.
NOTE: A successful printout indicates that the pclxl error is not driver related.
Item # 7
For problems with certain applications or documents, try modifying the HP LaserJet Family PCL6 Printer driver settings.
a. Place the mouse pointer over the printer icon, picture, or description and press the right mouse key.
b. Select "Properties" from the drop down menu.
c. When the "Properties" window opens up, select the "Finishing Tab."
d. Click the radio button to the left of "Custom" under the "Print Quality" section.
e. Click the "Details" button when it becomes bold.
f. From within the "Details" window, click on the drop down arrow to the right of the text box under the "Resolution" section.
g. From the drop down menu, select a lower resolution such as 600 dpi.
h. Click the "OK" button at the bottom of the "Details" window to close it and save the changes.
i. Then click the "OK" button at the bottom of the "Properties" window to close it.
j. Try printing a page from the document or application in question.
k. If desirable results have not been achieved, repeat Steps a through e.
l. From the "Details" window, in the "Font Headings" section, click the box to the left of "Send True Type as Bitmaps".
m. Click the "OK" button at the bottom of the "Details" window to close it.
n. Then click the "OK" button at the bottom of the "Properties" window to close it.
Item # 8.
Remove any additional memory that has been added to the printer after being purchased.
a. Refer to the User's Manual the was supplied with the HP LaserJet Family Printer for memory removal instructions.
Item # 9.
Try using a different Font within the application or document in question.
Item # 10.
Print using the PCL5 driver that came with your HP LaserJet Family Printer.
NOTE: If the PCL5 driver is not available use the latest preinstalled Microsoft driver available for your operating system.
Posted on Jun 23, 2009
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Pcl Xl error subsystem: text error:- Internal Error *50 operator: Begin char position:33
Your printer drivers are corrupted.
Delete the printer from your system.
Go out to www.hp.com
Select DRIVERS and SUPPORT
Enter your printer
Select the Operating System
Select DRIVERS.
Download the ones needed for your printer
Jun 02, 2011 | HP Laserjet CM2320fxi All-In-One Printer
PCL XL error
Okay,
You printer driver is telling you that it received a font call at data position 317 that called for a Windings font, but the printer cannot find the indicated font.
More than likely you have not enabled soft fonts to be included in the datastream and the printer has no choice but to search its internal fonts to find the fonts.
If it cannot, the driver reports the failure.
If you can create a print file for me, and send it to me at don.farr@msn.com, I will be able to read the datastream and possibly fix the failure for you.
Don
Jan 29, 2010 | Dell 1700n Laser Printer
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Error: InsufficientMemory
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
Dec 22, 2008 | Office Equipment & Supplies
PCL XL error
try to go to property then setting device button PDL and try to put pcl 5e
Sep 11, 2008 | Office Equipment & Supplies
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
PCL XL ERROR INSUFFICIENT MEMORY
you can try to use the HP 5L driver instead of the canon driver, I suspect you get this error when printing PDF files
Apr 17, 2008 | Office Equipment & Supplies
993 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
