Question about Kenmore 95002 / 95004 Electric Kitchen Range
My oven turns on but won't shut off have to unplug it
  • 2,509 Answers
You most likely need to replace the control and temp switch. It's not really safe to use you should have it done as soon as possible.
Posted on May 12, 2014
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Kenmore stoves
Do you have it in clean mode? Otherwise sounds like your temp control is out
Mar 19, 2014 | Ovens
Oven won t heat up properly
Hello Greg, I am happy to assist you. Let's try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If you have a gas range, while the unit is turn off; confirm that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. Then you may turn the appliance on. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. The unit could possibly be experiencing a potential wiring failure, faulty EOC (electronic oven control), sensor probe and/or bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Aug 05, 2013 | Frigidaire Kitchen Ranges
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Whirlpool interior light won't shut off
That is a really good question....what category did you post it under?
May 28, 2012 | Cars & Trucks
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Kenmore 95002 / 95004 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
