Question about Garden
Stihl chainsaw manual pdf
Model MS 261 C Ser. no.E197/68SH3-11A (2010 /26058301 How do we know how to order the right chain and bar? Where and how do you determine the length of the bar and chain? We use our chainsaws for wood purposes only.Please could you assist?
  • 24 Answers
  • 14 Answers
SOURCE: Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
  • 76 Answers
SOURCE: Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
Posted on Jul 19, 2009
SOURCE: talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
Posted on Apr 21, 2010
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual:
Spark plug (resistor type): Bosch WSR 6 F
Electrode gap: 0.02 in. (0.5 mm)
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-MS-210-230-250-Instruction-Manual.pdf
Apr 28, 2014 | Standard Oregon Chainsaw Chain For Stihl...
Chain keeps comming off my stihl 044
Download manual at:
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/044_Manual.pdf
Go to page 26. Remember to pull front of chain bar up before you tighten nuts. Make sure you really tighten nuts so they do not allow bar to move when finished.
Nov 20, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Where do I find a operating manual for my STIHL 210 Chain Saw ?
Don't believe everything you read.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
This was returned from my attempt:
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
IPLs (parts lists) are proprietary and not available to anyone not a Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Mar 21, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
User manual required for Stihl Chainsaw model MS 260
You can go right to Stihls website, and print off a PDF copy.
www.stihl.com
Please let me know if you found it ok.
Feb 09, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Need to strip down a Stihl MS 180 C chainsaw to get at the clutch.
Chain cover removal for all model 180s is illustrated under "Mounting the Bar and Chain"
http://www.stihlusa.com/stihl_ownersmanuals/MS170_180_Manual.pdf
It has an inboard clutch, this may help.
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care. HTH
Lou
Feb 08, 2010 | Garden
Stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
Apr 09, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
