Question about Traeger Industries Grilling
On smoke setting my temp goes up over 300 degrees
Older model texan traeger with digital controller
    Novelist:
    Scholar:
  • 197 Answers
Traeger suggests realignment of the augur for grills that are not getting hot enough. I wonder if this might be the same solution for grills that are getting too hot.
Here's their solution which I copied from the Traeger website at http://www.traegergrills.com/.
I've been noticing that my grill temperature keeps dropping lower. What is the problem?
You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
You might want to contact Traeger at their website to verify that this is a solution for overheating. In the above case, the improperly aligned augur was not dropping enough pellets in the firepot. In your case, it sounds like it may be dropping too many. This sounds like a routine maintenance thing that ought to be done periodically anyway.
Posted on Dec 04, 2014
5 Suggested Answers
  • 332 Answers
SOURCE: I have a Traeger Executive 100 with a digital
Call Traeger direct.
You have a bad control unit
Mike Treager is really good about replacing anything that goes wrong
Posted on Mar 07, 2010
  • 34 Answers
SOURCE: I was given a texan smoker
Yes you can. The digital control goes in place of the old controller and it is a un plug and replug in the ends. Make sure you keep track of what color plug in what color. Some have a purple dot to purple wire, orange dot to orange wire etc., but I don't know for sure on the older grills. Just write it down and be safe. FIRST make sure you unplug the grill before you start and DO NOT plug in till you have the new controller in place. It will short out when you touch the side if it is not unplugged.
Posted on Apr 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Traeger Grill has inconsistent smoke temperature
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
  • 4736 Answers
SOURCE: why is smoke coming out
Not sure which Model Traeger Grill/Smoker you have, but they all work pretty much the same way.
The following is a link to the model BBQ055. It should help you solve the problem, which simply may be an incorrect adjustment. If that doesn't help call Technical Service @ 1-800-872-3437.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ055_Manual.pdf
Posted on Feb 14, 2011
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Not smoking
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
Mar 30, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Does not heat to right temp.
You didn't give any specifics which makes it difficult to respond because there are many reasons why a Traeger grill might not heat to the right temperature.
One of the most common is problems is the outside temperature. If it's hot, the Traeger may overheat unless it is tended constantly. When it's cold, the Traeger may not get as hot as it should based on a normal setting and you may have to set it higher to reach the temperature you want.
Other reasons could be mechanical in that the hot rod may not be keeping the firebox as hot as it should or the fan may not be running as hard as it should to get the temperature to the right setting.
If your firebox has not been cleaned, ash will effectively insulate the fire, preventing heat from building up in the cooker.
Some people clean their Traeger thoroughly after every use. Some never clean theirs until something goes wrong. I clean mine after every 4-6 uses, depending on how long my cooking sessions have been.
If I've been cooking pork shoulder low and slow for many hours, I'll clean it more often than if I had grilled steaks multiple times for 15-20 minutes at a time.
Likely, if you're cooking in "normal" outside temperature of 60-80 degrees, your Traeger should be holding fairly close to the temperature you've set. If it's not then you may have a fan or hot rod problem and you ought to contact Traeger to set what they suggest.
Mar 03, 2014 | Traeger Industries BBQ075 All-in-One Grill...
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I turned off my grill yesterday and it kept on smoking. There seems to have been a fire at the base of the pellet bin. How can I fix this fast? I have three events beginning on Saturday, where my...
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Jun 30, 2011 | Traeger Industries BBQ125 All-in-One Grill...
Why is smoke coming out of the pellet box. Temp is set on smoke and it is rising up to 380 degrees
Feb 14, 2011 | Traeger Industries Grilling
Mar 24, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Grilling Logo
530 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
