Question about Refrigerators
Samsung refrigerator defrost problem
RF217ACWP I replaced the control board and the defrost heater and thermostat and still the frig does not defrost. What other components control the defrost cycle? Please help.
  • 1,548 Answers
Check the defrost drain hose. If it is plugged, the water from defrosting has no place to go, so defrosting doesn't do much.
Also, make sure you have power to the defrosting circuit (you may have a problem with the wiring). The simplest and safest means is to do a continuity check of the wires between the control board and heater with the refrigerator unplugged, or unplug the heater connection to the control board and measure the resistance of the heater through the connector(s). If it is open or very high, examine the wire terminals for corrosion. If the defrost control board is separate from the rest of the refrigerator control system, check for power coming into the board.
Posted on May 12, 2014
  • 110 Answers
SOURCE: Defrost heater not cycling
sound like to me you have a wire terminal short on the neutral side between you def. t-stat and the adc
go to www.servicematters.com for the service bulletin on this issue
Posted on Jun 01, 2008
  • 1462 Answers
SOURCE: Air Flow to Refrigerator keeps getting blocked by ice buildup
yes it is but check any plug and socket wiring as well
Posted on Aug 31, 2008
  • 958 Answers
SOURCE: Defrost Heater Resistance Range
21.3 ohms is just fine for a defrost heater. this heater is low wattage since it is an adaptive defrost. you could have problem with temperature sensor since you have replaced the board already.
tnx for using fixya,
drcool
Posted on Sep 30, 2008
farfield
  • 462 Answers
SOURCE: Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Posted on Apr 17, 2009
bobicehouse
  • 1524 Answers
SOURCE: Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Posted on Apr 26, 2009
Ice forming on bottom of freezer compartment Samsung RF4287HARS.
dont worry about it, you probably didnt get the freezer drawer closed all the way. frost will form when it doesnt get closed properly. just make sure it is closed now and the unit will clear the frost in a few days thru normal defrosting cycles. be sure that the drawer is closing on all sides by looking at the gasket and all should be ok in the future.
Nov 02, 2013 | Samsung RF4287HARS French Door...
Ge side by side frig won't defrost gss25sgmb new heater motherboard thermostats
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
Aug 14, 2012 | GE GSS25SGMBS Side by Side Refrigerator
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Frig stops cooling. freezer on bottom. frig is running just not cooling. made in 2008. we clean it let it set for 24 hr it cools again. is there a defrost heater that we can turn on, to solve this problem.
Hi, this model i believe has a calrod heater, and those usually dont go bad very often, its more than likely a bad defrost thermostat or control board, the thermostat is located in the freezer behind the back panel on the evaporator, the control board if it has one is going to be up in the control panel by the the thermostat, if it doesnt have a control board it will have a timer, I would change the timer and the thermostat in that case. It is also possible you have a bad heater which is also located in the freezer behind the back panel, under the evaporator, If you know how to use a meter you check this heater with an ohm meter. Let me know if you need further assistance.
Sean
Mar 26, 2011 | Whirlpool Refrigerators
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Self defrosting not defrosting not cold in bottom of frig has top freezer
How to checkeverything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ge frig does not freeze on freezer side
How to check everything
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is not cooling like it should. I
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Frost in freezer, ice thawed and frig not very cold...what could it be?
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
